MHB -c5.LCM and Prime Factorization of A,B,C
The least common multiple (LCM) of A, B, and C is calculated by taking the highest power of each prime factor present in the numbers. For A = 2 * 3^2 * 7 * 13 * 23^8, B = 2 * 3^5 * 5^9 * 13, and C = 2 * 5 * 11^8 * 13^3, the LCM is determined to be 2 * 3^5 * 5^9 * 7 * 11^8 * 13^3 * 23^8. The prime factorization of the LCM reflects the highest powers of each prime factor found across A, B, and C. This calculation emphasizes the importance of identifying the correct prime factors and their respective powers. The final expression for the LCM is 2 * 3^5 * 5^9 * 7 * 11^8 * 13^3 * 23^8.
karush
MHB
Build the least common multiple of A, B, and C
Then write the prime factorization of the least common multiple of A, B, and C.
$A = 2 \cdot 3^2 \cdot 7 \cdot 13 \cdot 23^8$
$B = 2 3^5 \cdot 5^9 \cdot 13$
$C = 2 \cdot 5 \cdot 11^8 \cdot 13^3$
$\boxed{?}$
ok this only has a single answer
definition: Prime factorization is a way of expressing a number as a product of its prime factors.
A prime number is a number that has exactly two factors, 1 and the number itself.
so is our first step $A\cdot B \cdot C$
Mathematics news on Phys.org
No, of course not. ABC would be a "common multiple" of A, B, and C but the "LEAST common multiple" only if all three numbers are relatively prime which is not the case here. I see that A and C have a factor of 2 so the LCM will have a factor of 2. A has a factor of [math]3^2[/math] so the LCM will have [math]3^2[/math] as factor. B has a factor of [math]5^9[/math] and C has a factor of 5 so the LCM will have [math]5^9[/math] as a factor. B has 7 as a factor so the LCM has 7 as a factor. C has a factor of 11 so the LCM will have 11 as a factor. A and B have 13 as a factor and C has [math]13^3[/math] as a factor so the LCM will have [math]13^3[/math] as a factor. A has [math]23^8[/math] as a factor and [math]23^5[/math] so the LCM has [math]23^8[/math] as a factor.
The least common multiple of A, B, and C is [math]2(3^2)(5^9)(7)(11)(13^3)(23^8)[/math].
sorry I just noticed that $B=2\cdot 3^5\cdot 5^9 \cdot 13$
probably will change every thing
I should just OP the screenshots
You still use the same principal:
for the greatest common factor of a set of numbers, take the product of all primes to the smallest power in the given set and for the least common multiple take the product of all primes to the highest power.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
