Cal 2 integral / trig substitution
In summary, the conversation is discussing a problem involving proving a statement using trigonometric substitutions. The conversation includes equations and steps for solving the problem, and a suggestion to make another substitution.
ryantruran2
I am asked to prove the following statement is correct
integral (sqrt(a^2+x^2))/x dx = sqrt(a^2+x^2)-a log(a (sqrt(a^2+x^2)+a))+ C
x = atanθ
dx = (asecθ)^2
tan^2+1 = sec^2
got down to a (sec^2 θ a(√sec^2)dθ)/atanθ
I plugged into wolfram and immediately got something involving csc in the steps and I am not sure where it came from. Just beginning these trig substitutions in class.
[tex]
x = atan \theta
[/tex]
[tex]
dx = a sec^2 \theta d\theta
[/tex]
so subbing into the integral you get (might want to check the steps)
[tex]
\int \frac{sqrt{a^2+x^2}}{x}dx
= \int \frac{\sqrt{a^2+a^2tan^2 \theta}}{atan\theta} a sec^2 \theta d\theta
= \int \frac{\sqrt{a^2sec^2\theta}}{tan\theta} sec^2 \theta d\theta
= \int \frac{a}{cos\theta}\frac{cos\theta}{sin\theta} \frac{1}{cos^2 \theta} d\theta
= \int a\frac{1}{sin\theta} \frac{1}{cos^2 \theta} d\theta
[/tex]
now can you make another substitution?
would you use
U= secθ
dU =sec(θ)tan(θ)
FAQ: Cal 2 integral / trig substitution
What is a "Cal 2 integral"?
A "Cal 2 integral" refers to an integral, or mathematical calculation, that is typically taught in a Calculus 2 course. It involves using various techniques to find the area under a curve or the volume of a solid, among other things.
What is "trig substitution" in the context of Cal 2 integrals?
Trig substitution is a technique used in Calculus 2 to simplify integrals involving trigonometric functions. It involves substituting a trigonometric expression for a variable in the integral, making it easier to solve.
How do you know when to use trig substitution in a Cal 2 integral?
Trig substitution is typically used when the integral involves a combination of algebraic and trigonometric functions, and the algebraic expression cannot be easily integrated. It may also be used when the integral contains a radical expression.
What are the steps for using trig substitution in a Cal 2 integral?
Step 1: Identify the appropriate trigonometric substitution to make, based on the form of the integral.
Step 2: Substitute the trigonometric expression for the appropriate variable in the integral.
Step 3: Use trigonometric identities to simplify the integral.
Step 4: Solve the simplified integral.
Step 5: Substitute the original variable back into the solution to get the final answer.
Are there any common mistakes to avoid when using trig substitution in Cal 2 integrals?
Yes, some common mistakes to avoid include using the wrong trigonometric substitution, forgetting to convert the limits of integration, and making errors in simplifying the integral using trigonometric identities. It is important to carefully follow the steps and double-check your work to avoid these mistakes.
