Calc 2 - Taylor Expansion Series of x^(1/2)
The discussion focuses on finding the Taylor expansion series for the function f(x) = √x at a = 4. The user has calculated the derivatives of f(x) but struggles to identify the pattern in the numerators of the derivatives. They note that the numerators appear to follow a sequence involving odd numbers, specifically 1, 1*1, 1*1*3, and so forth. Another participant clarifies that the numerators relate to the double factorial of odd numbers, which is defined recursively. The conversation emphasizes the importance of recognizing these patterns in Taylor series expansions.
omg4cards
f(x) = \sqrt{x}, a = 4
f(x) = \sumf^{n}(a)/n! (x-a)^{n}
f(x) = x^{1/2}
f^{'}(x) = \frac{1}{2}x^{1/2}
f^{2}(x) = -\frac{1}{2}*\frac{1}{2}x^{-3/2}
f^{3}(x) = \frac{1}{2}*\frac{1}{2}*\frac{3}{2}x^{-5/2}
f^{4}(x) = -\frac{1}{2}*\frac{1}{2}*\frac{3}{2}*\frac{5}{2}x^{-7/2}
f^{n}(x) = (-1)^{n+1}*\frac{1}{2}^{n}*x^{-[(2n-1)/2]}*?
The problem I am having here is with identifying the pattern. I am able to describe everything except the numbers in the numerator(1, 1*1, 1*1*3, 1*1*3*5...). Any help is greatly appreciated!
I have no idea why it looks like that...
shouldn't the number's in the numerator be (1*-1*-3*-5*...)?
I left out the signs to simplify and becaus I already identified the pattern w/ (-1)^(n+1)... so if i kept the signs in, the #'s in the numerator would be (1, -1*1, -3*-1*1, -5*-3*-1*1)
how are you trying to explain it then?
n! denotes the double factorial of n and is defined recursively for odd numbers,,
eg: 9! = 1 × 3 × 5 × 7 × 9 = 945
does that help?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
  • · Replies 105 ·
