Calc Commutator in Infinitely Potential Well: Is it Possible?
  • Thread starter LagrangeEuler
  • Tags
    Commutator
In summary: But for the actual potential, you can only get eigenstates of the hamiltonian if you squish the potential into a very small box, and then it's not the same anymore.
  • #36
samalkhaiat said:
My reasoning was based on the premiss that the particle IS a FREE particle.
This linear combination DOES NOT represent a FREE PARTICLE:
1)free particles do not just flip the sign of their momenta.
2) it can be made proportional to [itex]\sin ( p x )[/itex] which is not a free particle wavefunction. So to restrict the solutions of [itex]P^{ 2 } \psi = p^{ 2 } \psi[/itex] to a free particle, you should set [itex]b = 0[/itex] or [itex]a = 0[/itex].
The main issue regarding the particle in the box is the following: Inside the box, the particle is never a free particle.
I do not understand what you mean. Also for a free particle (a special case for a particle in a finite potential, namely [itex]V=0[/itex] by the way) the two generalized momentum eigenfunctions are [itex]u_{p}[/itex] and [itex]u_{-p}[/itex] both are eigenfunctions of [itex]\hat{p}^2=-\partial_x^2[/itex] and so is any linear combination. Any non-trivial linear combination is, however, obviously not a generalized eigenfunction of [itex]\hat{p}[/itex], which disproves your claim that any eigenfunction of [itex]\hat{p}^2[/itex] must be also one of [itex]\hat{p}[/itex]. The other way is right, i.e., any eigenfunction of [itex]\hat{p}[/itex] is also an eigenfunction of any operator that is a function of [itex]\hat{p}[/itex].
<h2> What is a commutator in an infinitely potential well?</h2><p>A commutator in an infinitely potential well is a mathematical operator that represents the difference between two operators. In the case of an infinitely potential well, the commutator is used to describe the relationship between the position and momentum operators.</p><h2> Why is the commutator important in an infinitely potential well?</h2><p>The commutator is important in an infinitely potential well because it helps us understand the behavior of quantum particles in this system. It allows us to determine the uncertainty in position and momentum measurements, as well as the energy levels of the system.</p><h2> How is the commutator calculated in an infinitely potential well?</h2><p>The commutator in an infinitely potential well is calculated using the standard commutator formula: [A, B] = AB - BA. In this case, A represents the position operator and B represents the momentum operator. The result of the calculation will depend on the specific values of A and B.</p><h2> Is it possible to calculate the commutator in an infinitely potential well?</h2><p>Yes, it is possible to calculate the commutator in an infinitely potential well using the formula mentioned above. However, the result will depend on the specific values of the position and momentum operators and may not always have a physical interpretation.</p><h2> How does the commutator affect the behavior of particles in an infinitely potential well?</h2><p>The commutator affects the behavior of particles in an infinitely potential well by determining the uncertainty in position and momentum measurements. It also affects the energy levels of the system and can provide insight into the dynamics of quantum particles in this system.</p>
FAQ: Calc Commutator in Infinitely Potential Well: Is it Possible?
