Shirish
- 244
- 32
I'm reading the Feynman lectures chapter on "Curved Space", section 6-2. Say we're trying to figure out a way to measure average curvature on Earth. We know that 3d space is curved if Euclidean geometry rules don't work - e.g. the ratio of circumference and radius of a circle isn't ##2\pi##, or angles in a triangle don't sum up to ##\pi##, etc. The described method is:
Then later on to measure curvature near Earth,
My confusion is: to calculate ##M## we're using ##4\pi\rho r^3/3##. But didn't we just argue that standard geometry rules may not work in curved space? For example the surface area formula sure doesn't seem to work. So why should the sphere volume rule work? Just as we measured the surface are by laying out a fine-scale rectangular grid on the surface, wouldn't we be forced to measure volume by laying out fine-scale cubical grid inside the Earth? Is there any assumption or mathematical result that I'm missing?
We can specify a sphere by taking all the points that are the same distance from a given point in space. Then we can measure the surface area by laying out a fine-scale rectangular grid on the surface of the sphere and adding up all the bits of area. According to Euclid the total area ##A## is supposed to be ##4\pi## times the square of the radius; so we can define a "predicted radius" as ##\sqrt{A/4\pi}##. But we can also measure the radius directly by digging a hole to the center and measuring the distance. Again, we can take the measured radius minus the predicted radius and call the difference the radius excess. $$r_{excess}=r_{meas}-\bigg(\frac{\text{measured area}}{4\pi}\bigg)^{1/2}$$
The rule that Einstein gave for the curvature is the following: If there is a region of space with matter in it and we take a sphere small enough that the density ##\rho## of matter inside it is effectively constant, then the radius excess for the sphere is proportional to the mass inside the sphere. $$\text{Radius excess}=r_{meas}-\sqrt{\frac{A}{4\pi}}=\frac{G}{3c^2}.M$$ where ##M=4\pi\rho r^3/3## is the mass of the matter inside the sphere.
(Earth assumed to have uniform density) Suppose we were to measure the surface of the earth very carefully, and then dig a hole to the center and measure the radius. From the surface area we could calculate the predicted radius we would get from setting the area equal to ##4\pi r^2##. When we compared the predicted radius with the actual radius, we would find that the actual radius exceeded the predicted radius by the amount given in the above equation.
