MHB Calc Expected Value & Variance of Multivar. Func.
The discussion focuses on calculating the expected value and variance of a multivariable function involving two normally distributed variables, X and Y. The user struggles to derive the probability density functions f(x) and g(y) necessary for applying the properties of expected values. They correctly identify the normal distribution parameters for X, including its mean and variance. The response provides the correct form of the probability density function for X and suggests a similar approach for Y. Understanding these functions is essential for solving the problem effectively.
TheFallen018
Hey, I've got this problem that I've been trying to crack for a while. I can't find any info for multi-variable expected values in my textbook, and I couldn't find a lot of stuff that made sense to me online. Here's the problem.
Find $E(C)$
Find $Var(C)$
I tried to get the limits from the normal distributions that were given. If I was doing it right, I had
$90\leq X \leq 130 $
$1.9\leq Y \leq 2.9$
for X and Y.
I think my main problem is that I'm not sure how to get $f(x)$ and $f(y)$ so that I can use the property
$E(aX+bY) = aE(X)+bE(Y)$
and
$E(x) = \int_{n}^{m}x*f(x)dx$
where $n \leq f(x) \leq m$.
I think I might be able to figure it out once I can work out what the functions should be, but I'm a little stuck here. Any help would be awesome. Thanks.
Mathematics news on Phys.org
You are told that X is normally distributed with mean 110 and standard deviation 20 (I am assuming that the second number, "$20^2$" is the variance that is the square of the standard deviation.) Whoever gave you this problem clearly expects you to know what the "normal distribution" is! The "f(x)" you want is $\frac{1}{\sqrt{2(\pi)(20^2)}}e^{-\frac{(x- 110)^2}{2(20^2)}} = \frac{1}{20\sqrt{2\pi}}e^{\frac{(x- 110)^2}{800}}$ and similarly for g(y). (You have "f(x)" and "f(y)" but they are not the same function!)
Look at https://en.wikipedia.org/wiki/Normal_distribution
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
