[Calc] First max and min values of an underdamped oscillation
In summary: You are confused because you appear to be simply guessing. Your starting point should be ##3x+n\pi=\arctan(\frac{21}{22})##.That's the equation that describes your extrema. You found the first one by setting ##n=0##. If you set ##n=1## and solve for ##x## you will find that ##x## is negative, right?
DanRow93
25
Determine the FIRST maximum and minimum values of the underdamped oscillation:
y=e^(-x/2)(4sin(3x)+3cos(3x)) cm
3. The Attempt at a Solution [/B]
I firstly differentiated the above equation and got:
(-e^(-x/2)(22sin(3x)-21cos(3x)))/2
I checked this and it is correct.
Next I set this equation to = 0
I crossed off the exponential function (it can't equal 0?) and the /2 on the bottom.
22sin(3x)-21cos(3x)=0
21=22tan(3x)
tan(3x)=21/22
tan^(-1)(21/22)=0.7621
I plotted the graph online and checked this point, but it's definitely not a maximum or minimum, so I don't really understand; I thought that I could put dy/dx = 0 and that would tell me the points.
Also, this has only given me one point. How will I find the next point? Tan^(-1)(a number) only gives one definitive value.
I know that I can take the second derivative and that will tell me if the point is a maximum or minimum (+for minimum,-for maximum).
Can anyone help me understand how max and min works for this kind of equation? The oscillation gradually gets smaller, which I haven't ever done before.
Thank you!
DanRow93 said:
tan(3x)=21/22
Be careful here. Write an equation for x.
What is the periodicity of tan?
Sorry that should be the value of 3x, so x=0.7621/3 = 0.254
And that does appear to be the first maximum!
Then I could prove that it is a maximum by taking the second derivative.
Tan has a period of Pi radians... Maybe I'm being stupid but I don't know how I find what the period is in terms of x.
When I do work it out though, I add half of one period to 0.254?
Edit:
tanx= tan(x+n*π)
So I put my value of x in here, but which number do I use for n?
I tried tan(0.254+(0.5*π)) but that wasn't right. n is an integer, but which integer?
Edit:
tanx= tan(x+n*π)
Think about it. You've got ##3x+n\pi=\arctan(\frac{21}{22})##. You've got the ##n=0## solution. What value of ##n## is going to give you the next largest value of ##x##?
Well l would think it would be n=0.5, seeing as 1π is one period of tan, and I am adding half of a wave length?
You already said that doesn't work and it gives you a smaller value for ##x##. ##n## needs to be an integer. Hint: ##n## can be negative.
I found the right answer. I did (3x+1π)/3
I'm still confused as to how this works though, because looking at the graph that I plotted of y=e^(-x/2)(4sin(3x)+3cos(3x)) it is only half of a wavelength from Maximum to Minimum, so why am I adding 1π, which is one whole wavelength of tan?
That's the equation that describes your extrema. You found the first one by setting ##n=0##. If you set ##n=1## and solve for ##x## you will find that ##x## is negative, right? That's not it. How about trying ##n=-1##??
I do understand the equation, so:
x = (arctan(21/22) + 1π)/3
I'm just stuck with how to know what n equals.
I know this is dumb because it's probably the simplest part of the whole task, thanks for being patient.
That's ok. You may be looking for some deep answer. If you look at ##3x+n\pi=\arctan(\frac{21}{22})## you can see as ##n## increases, ##x## decreases. If ##n## decreases then ##x## increases. The smallest positive solution was at ##n=0##. So the next positive solution will be at ##n=-1##. The next one would be ##n=-2## etc etc. That's all there is to it.
Ok thank you! I guess I was looking into it too much.
Related to [Calc] First max and min values of an underdamped oscillation
1. What is an underdamped oscillation?
An underdamped oscillation is a type of oscillation that occurs when a system is subjected to a force that is less than the amount needed to sustain a constant motion. This causes the system to oscillate around a stable equilibrium point, with the amplitude of the oscillation gradually decreasing over time.
2. How do you calculate the first maximum and minimum values of an underdamped oscillation?
The first maximum and minimum values of an underdamped oscillation can be calculated using the following formula:
Maximum value = A + A*e^(-ζωnt)*cos(ωdt)
Minimum value = A - A*e^(-ζωnt)*cos(ωdt)
Where A is the amplitude of the oscillation, ζ is the damping ratio, ωn is the natural frequency, and ωd is the damped frequency.
3. What factors affect the first maximum and minimum values of an underdamped oscillation?
The first maximum and minimum values of an underdamped oscillation are affected by the amplitude, damping ratio, natural frequency, and damped frequency of the oscillation. These values can also be influenced by external forces acting on the system, such as friction or air resistance.
4. How does the damping ratio affect the first maximum and minimum values of an underdamped oscillation?
The damping ratio is a measure of the amount of damping present in a system. A higher damping ratio will result in a faster decrease in amplitude and a shorter period of oscillation, leading to smaller first maximum and minimum values. On the other hand, a lower damping ratio will result in a slower decrease in amplitude and a longer period of oscillation, leading to larger first maximum and minimum values.
5. What is the significance of the first maximum and minimum values in an underdamped oscillation?
The first maximum and minimum values of an underdamped oscillation provide important information about the behavior of the system. They can be used to determine the amplitude, period, and frequency of the oscillation, as well as the presence and amount of damping. Additionally, these values can be used to predict the future behavior of the system and make adjustments to optimize its performance.
