Calc I derivatives, I know the answers, but how did I get there?
In summary, the conversation discusses finding parallel tangent lines for two functions, x^2 and -x^2+2x-5, and finding the equation of a tangent line that intersects both graphs only once. The solution involves setting the derivatives of the two functions equal to each other and solving for the x value where the tangent lines are parallel. The final step is to find the equation of the tangent line using the points where it intersects the two functions.
i2c
Question #2
http://img830.imageshack.us/img830/8185/0000825.jpg
I can of course find the derivatives for both functions. When I set them equal to each other I get x=1/2 that's where the functions have parallel tangent lines for the same x value, however (I think that) the functions have parallel tangents everywhere, just at different x values. So I figured out that at any point x on x^2, there will be a parallel tangent from -x^2+2x-5 at 1-x
I guess you have to find the equation of a tangent line that intersects with both graphs only once, no more no less, but I don't know how to write that out and solve for it. The answers are the tangent lines when x = -1 and 2 on x^2
Label the point where the line intersects the upper parabola (a, a2) and the point where it intersects the lower parabola (b, -b2+2b-5). So those are two points on the line, and you also found that b=1-a. That should be enough to figure out the equation of the line, I think.
FAQ: Calc I derivatives, I know the answers, but how did I get there?
What is a derivative?
A derivative is the rate of change of a function at a specific point. It represents the slope of a curve at that point.
How do you find the derivative of a function?
To find the derivative of a function, you can use the power rule, product rule, quotient rule, or chain rule. These rules involve taking the derivative of each term in the function and combining them using algebraic operations.
What is the purpose of taking derivatives?
Taking derivatives allows us to find the rate of change of a function, which has many practical applications in fields such as physics, economics, and engineering. It also helps us find the maximum and minimum values of a function.
What are the common notations for derivatives?
The most common notations for derivatives are: dy/dx, f'(x), and d/dx(f(x)). These notations represent the derivative of a function f(x) with respect to x.
How do you use derivatives to find the slope of a tangent line?
To find the slope of a tangent line at a specific point on a curve, you can use the derivative of the function at that point. Plug in the x-value of the point into the derivative, and the resulting value will be the slope of the tangent line.
