Calc III: minimize the area of an ellipse
In summary: Is that right?In summary, the problem is trying to find a and b that minimize the area of an ellipse that encloses a circle. The ellipse equation is y^2=b^2/a^2(a^2-x^2), and the circle equation is x^2+y^2=2x. The attempt at a solution was to solve for y^2[y^2=b^2/a^2(a^2-x^2)] and plugging that into the circle equation, then getting dy/dx but that
Vols
1. Problem: ellipse x^2/a^2 + y^2/b^2 = 1 encloses circle x^2 + y^2 = 2x. Find values of a and b that minimize the area of the ellipse.
: [/B]A = pi*a*b for an ellipse.
: [/B]I tried a bunch of crazy stuff... I know I need to find where the tangents (1st derivatives) are equal for the ellipse and circle (at two intersections where x's are equal and y's will be mirrored across the x axis). Or I think I know that... I can do the implicit differentiation to get me the dy/dx for the ellipse and circle [-xb^2/ya^2 and (1-x)/y respectively] but I set them equal and don't really get anything out of it, so I tried solving the ellipse equation for y^2 [y^2=b^2/a^2(a^2-x^2)], plugging that into the circle equation, then getting dy/dx but that didn't seem to work either. I felt like I was making progress several times but now I just feel like I'm going in circles (or ellipses)... I can show much more of what I tried if it helps. I am still working on it as I post this.
P.S. I just looked over an old (2008) thread here about a very similar problem which seems to be helping but I still can't quite get there with what I just read.
You can calculate the point where circle and ellipse meet as function of a and b. dy/dx should be the same for ellipse and circle at that point, which gives you one condition on a and b.
Start with making a sketch of the circle and a tentative ellipse. You'll have to do a little algebra to figure out the center and radius of the circle.
I can't see where the radius/center of the circle play into finding a and b.
Also: I got y^2=b^2/a^2(a^2-x^2) and plugged that into the circle equation to get 2x - 2b^2x/a^2 - 2 = 0 in an attempt to get things in terms of a and b but it doesn't seem to be the right track.
Except the ellipse and the circle don't share a common center. This is something a sketch would make clear.
The first thing I did was pull it up on desmos. Still not sure how it helps to know that.
I get that it is significant to know that in order to solve. But I don't see how it actually is used to calculate a and b.
OK. I just found out that I missed the whole section on lagrange multipliers. Knowing that this was missing from my arsenal makes me feel a bit better, but, having only just read about them, I'm still having a bit of trouble. I want to minimize my objective function for area, f(a,b)=a*b*pi, but I'm not sure about my constraints or how to get them in terms of a and b. I know the ellipse and circle share 2 points with the same x values (b/w .5 and 1) and that the tangents at those points will have the same slope for both the ellipse and the circle. Also, the ellipse equation must be constrained to outside (or on) the circle at all points but that is a constraint on the wrong equation. I think with a bit of guidance I can understand the application of lagrange multipliers conceptually and figure out what to do, but the book is just horribly technical and isn't giving me the insight I'm after.
SteamKing: I don't understand what your advice is aiming for. Vols works with the equations, those equations are satisfied and you don't have to know centers of objects or anything else.
Where does that range come from?
You should get x of the intersection point as function of a and b.
By setting y2 from the ellipse equal to y2 for the circle you get an equation that contains x, a and b only. You can use the expression for x gained above and plug it in, it will give you an equation with a and b only. Solve for one of them, plug it into the formula for the area, and you have a one-dimensional minimization problem.
Holycrapthankyou! I have the equations done from previous attempts, I just need to sort through and plug everything in the right places. I will report back after I get a chance to do that - so much to do, so little time - but it makes sense to me sitting here right now (subject to change, ha) so I just wanted to say thanks, mfb.
EDIT: Where I said b/w .5 and 1 I meant b/w 1 and 2.
Likes mfb
Related to Calc III: minimize the area of an ellipse
1. What is the formula for the area of an ellipse?
The formula for the area of an ellipse is A = πab, where a and b are the semi-major and semi-minor axes of the ellipse, respectively. It can also be written as A = πr1r2, where r1 and r2 are the radii of the ellipse.
2. How do you minimize the area of an ellipse?
The area of an ellipse can be minimized by finding the critical points of the function A = πab. This can be done by taking the partial derivatives with respect to a and b, setting them equal to 0, and solving for a and b. The resulting values will be the semi-major and semi-minor axes that minimize the area of the ellipse.
3. What is the relationship between the area of an ellipse and its eccentricity?
The area of an ellipse is inversely proportional to its eccentricity. This means that as the eccentricity increases, the area of the ellipse decreases. When the eccentricity is 0, the ellipse becomes a circle and has the maximum area.
4. Can the area of an ellipse be negative?
No, the area of an ellipse cannot be negative. The formula for the area of an ellipse only outputs positive values. However, it is possible for the area to be equal to 0 if the ellipse is degenerate (i.e. when the semi-major or semi-minor axis is 0).
5. Are there any real-world applications of minimizing the area of an ellipse?
Yes, minimizing the area of an ellipse has many real-world applications in fields such as engineering, architecture, and mathematics. For example, it can be used to design the shape of mirrors or lenses in order to minimize the amount of material used while still maintaining the desired optical properties.
