marcophys
- 152
- 20
I have acquired a new compressor rated at 540 L/min @ 7 bar 150L tank
I decided to test this at 23 degC, timing compression at 2 bar intervals (0-2, 2-4 etc.)
I was surprised to find that it maintained 34 seconds at each interval up to 8 bar (but this could be poor experimental controls)...(300L/34)*60 = 529.4 L/min
I thought... that's pretty good, we don't know the exact size of the tank... so I guess it is a true 540 L/min.
However, the @ 7 bar seems redundant, because there was no apparent change.
I set up a spreadsheet to understand different compression rates at different temperatures, but I may have failed.
V1 = normal liters per minute = V1 = (P2/P1*T1/T2)*V2
V2 = liters per minute = V1/(P2/P1*T1/T2)*V2
T1 = temperature at normal conditions = 273.15K
T2 = actual temperature of air = T1 + air temp in Celcius
P1 = pressure at normal conditions = 101.325 kPa
P2 = actual pressure = say 7 bar = 709.275 or 810.6 Kpa (not sure - I chose 810.6kPa)
if V2 = 540 ...&... T2 = 273.15 (0C)
V1 = 4320 NL/min
I thought... knowing V1 @ 273.15K I could then find V2 @ 23 degC
But V2 = 585.47 L/min
V2 should less than 540 L/min
I then ran
if V2 = 540 ...&... T2 = 296.15 (23C)
V1 = 3984 NL/min
(V1 @ 0C) - (V1 @ 23C) = 336 NL/min
There is 336 NL/min less @ 23 deg C.
This made sense.
Using V1 = 336 NL/min
@ 23 C = 46 L/min
Therefore the compressor pumps 46L/min less at 23 degrees C as compared to pumping at 0 degrees C
Here's the spreadsheet:
https://drive.google.com/file/d/0B9HHPLN8L5Mxel9YU0oyNTIzZ2M/view?usp=sharing
I don't know if a manometer read @ 7 bar should be calculated at 7 or 8 bar.
But more than that...
I just don't know whether this maths is correct or not.
Can anybody confirm or deny this?
V1 = 4320 NL/min
I then ran
V1 = 3984 NL/min
This made sense.
@ 23 C = 46 L/min
