Calcium carbonate sample -> calcite or aragonite?
In summary, there are multiple ways to determine whether a calcium carbonate sample is calcite or aragonite. One way is to test its reaction with acid, with aragonite producing a stronger reaction with weak acids and calcite requiring stronger acids. Another way is to examine the sample under a microscope and look for distinct crystal forms, with calcite and aragonite having different forms. A chemical test using Feigl's solution is also a valid method.
Picasso
Calcium carbonate sample --> calcite or aragonite?
Is there a definite way to determine whether a calcium carbonate sample is calcite or aragonite? The weak bond of aragonite should produce an active reaction with a weak acid such as diluted acetic (vinegar), whereas calcite will require a stronger acid to produce an active reaction. Is this a valid test?
A powdered sample or a crystalline sample?
Consistency of sand.
Well you can try a look with modest power microscope e.g. 20-40x. If you can see any well defined crystal forms, it should be possible to distinguish by inspection since calcite and aragonite have different crystal forms. If you don't see any well defined crystal structures, then ... I can't help. You need a chemical test, x-ray test, areas I'm not familiar with.
Found a definite chemical test using Feigl's solution:
http://www.mindat.org/mesg-100-179708.html
Related to Calcium carbonate sample -> calcite or aragonite?
1. What is calcium carbonate sample?
Calcium carbonate sample is a mineral compound composed of calcium, carbon, and oxygen atoms. It is commonly found in nature in the form of limestone, chalk, and marble.
2. What is the difference between calcite and aragonite?
Calcite and aragonite are two different crystal forms of calcium carbonate. Calcite has a trigonal crystal structure, while aragonite has an orthorhombic crystal structure. They also have different physical properties, such as hardness and density.
3. How can you determine if a calcium carbonate sample is calcite or aragonite?
The crystal structure of calcite and aragonite can be determined using X-ray diffraction analysis. The different physical properties, such as hardness and density, can also be measured to identify the type of calcium carbonate present.
4. What are the common uses of calcite and aragonite?
Calcite and aragonite have various applications in industries such as construction, agriculture, and pharmaceuticals. Calcite is used in the production of cement, while aragonite is used in aquariums and as a source of calcium supplements.
5. Can calcite and aragonite be converted into each other?
Yes, calcite and aragonite can undergo a process called polymorphism, where they can be converted into each other under certain conditions of temperature and pressure. This process is known as the transformation of calcite to aragonite and vice versa.
  • Materials and Chemical Engineering
