Calcium Chloride based dessicant
The discussion centers on experimenting with solar air conditioning as a method for dehumidification. The proposed concept involves creating a suspension of Calcium Chloride or a lithium desiccant salt in oil, which would be heated in a solar boiler to evaporate water. This moisture-absorbing solution would then be used in a large air cleaner system, where an electric fan would draw in humid air, allowing the desiccant fluid to dry the air before it is expelled. A key point raised is the observation that relative humidity can increase even when air temperature decreases, highlighting the complex relationship between temperature, humidity, and the effectiveness of the proposed system.
trendset
Hello everyone.
I would like to experiment with solar air conditioning, wich may work as a massive dehumidifier.
I have the idea of making a suspension/solution of Calcium Chloride and / or some sort of Lithium dessicant salt in some sort of oil, run between a solar boiler to evaporate water,on the outside, and then, feed that moisture hungry suspension / solution into something like a big oil wet air cleaner, where an electric fan / turbine would cause suction of damp air into the filter, the dessicant fluid would dry it and it would come out of this very dry.
This video has inspired me:
Chemistry news on Phys.org
Nicely presented, lengthy.
Note though that the Relative Humidity (RH) went UP (lower air temperature with the same amount of water vapor per volume of air).:doh:
Cheers,
Tom
Yes, it's because the real refrigerant is humidity itself, just tries to fill the void left by what has been absorbed and outward driven by means of this device.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
