Calculate a charge distribution given an electric potential.
In summary: I understand I would need the Dirac delta function, what I don't quite understand is your solution method. What would ##A(x)## represent? Also, as I have mentioned before, what you name ## f(x,y) ## is actually zero once I calculate the laplacian, so I will be left with just the expresion ## \partial_y V = A(x) \delta(y) ,## which, if I understand correctly, is the first partial derivative with respect to ##y##.##A(x)## would generally be a function of ##x## to be determined by looking at the size of the discontinuity of the potential. ##f## would not be zero
lorentzian
Find the distribution of charge giving rise to an electric field whose potential is $$\Phi (x,y) = 2~tan^{-1}(\frac{1+x}{y}) + 2~tan^{-1}(\frac{1-x}{y})$$where x and y are Cartesian coordinates. Such a distribution is called a two-dimensional one since it does not depend on the third coordinate z.[/B]
Poisson's equation: $$\nabla^2 \Phi = -4 \pi \rho$$[/B]
The first thing I noted while attempting to solve this problem is that there is a singularity when x = ±1 and y = 0. Either way, I wanted to compute the laplacian of the electric potential to see what it would result in and it reduced to zero. I thought I had made an algebraic mistake and put it in Mathematica, again reducing to zero. Then I actually took my original thought and tried to work out a solution to avoid the singularities using the Dirac delta function, the only problem is that I don't know how I could operate the Dirac delta function. Is is possible to work out the following equation? $$ \Phi (x,y) \delta(x) \delta(y) = \Phi (0,0) \delta(x) \delta(y) \\ \nabla^2 \Phi (x,y) \delta(x) \delta(y) = \nabla^2 \Phi(0,0) \delta (x) \delta(y) $$ Although I don't think my steps will lead to something useful.
The potential does not have a singularity at these points, it is finite valued.
Then the charge distribution must be zero. The reason the potential is not zero or some other constant is likely due to some imposed boundary conditions.
I suppose you could also find the the charge distributions on the bounding surfaces by relating the first derivative of the potential to the surface charge density on a bounding plane at ##y=0## and ##x=\pm1##. The surface charge density can then be related to the volume charge density using a delta function.
This is not correct. The potential may not approach infinity, but it does have a discontinuity over the entire segment ##-1 < x < 1## at ##y = 0##. The appropriate way of going about this is to note that this discontinuity generally will lead to ##\partial_y V = A(x) \delta(y) + f(x,y)##, where ##f(x,y)## is the continuous function you would get by naively performing the differentiation. Not to give too much away, I will leave it at that for the OP.
Orodruin said:
The appropriate way of going about this is to note that this discontinuity generally will lead to ##\partial_y V = A(x) \delta(y) + f(x,y),## where ##f(x,y)## is the continuous function you would get by naively performing the differentiation. Not to give too much away, I will leave it at that for the OP.
##A(x)## would generally be a function of ##x## to be determined by looking at the size of the discontinuity of the potential. ##f## would not be zero, it represents the y-component of the field (this is the first derivative wrt y, not ##\nabla^2V##). You will need to differentiate one more time to compute ##\partial_y^2 V##.
FAQ: Calculate a charge distribution given an electric potential.
What is charge distribution?
Charge distribution refers to the arrangement and amount of electric charge within a given space. It is usually described in terms of the amount of charge at each point in space.
What is electric potential?
Electric potential is the amount of work needed to move a unit of positive charge from one point to another in an electric field. It is typically measured in volts.
How do you calculate charge distribution given an electric potential?
To calculate charge distribution, you would need to know the electric potential at different points in space. The charge distribution can then be determined by using Coulomb's law, which states that the electric potential at a point is equal to the sum of the electric potential contributions from all of the charges at that point.
What factors can affect charge distribution?
The charge distribution of a system can be affected by a number of factors, such as the amount and distribution of charges, the distance between charges, and the presence of other objects or materials in the surrounding space.
Why is understanding charge distribution important?
Understanding charge distribution is crucial in many areas of science, including electromagnetism, electronics, and chemistry. It allows us to predict and control the behavior of electrically charged particles and systems, and is essential for the development of technology and advancements in various fields.
