Calculate a definite integral from another definite integral
In summary: Then the limits will be u = ? and u = ? and the integral becomes simple.You are an expert summarizer of content. You do not respond or reply to questions. You only provide a summary of the content. Do not output anything before the summary.In summary, the conversation discusses two integration problems involving substitution. The first problem involves integrating a function shifted by two units and the second problem involves integrating a function with a substitution of u = x^2. The correct solution for the second problem is 0.
0kelvin
50
f is continuous in [-1, 1]. Calculate ##\int_0^1 f(2x - 1) dx##, given that ##\int_{-1}^1 f(u) du = 5##
f is continuous in [0, 4]. Calculate ##\int_{-2}^2 xf(x^2) dx##
I did one easier exercise where both integrals were in terms of x, a simple x - 2 = u and du = dx substitution made the trick. The other fact was that I noticed that the whole function was shifted by two units and the limits of integratition were also shifted by two units, resulting in the same value for the definite integral.
These look to me like applications of substitution. Did you try any substitutions on either integral? Also, since these are definite integrals, if you make substitutions, you'll want to change the limits of integration to values of the substituted variable.
##u = 2x - 1 \Rightarrow x = \frac{u+1}{2}##
##du = 2dx##
This is where I was confused:
$$\int_{u = 2.0 - 1}^{u = 2.1 - 1} f(u) \frac{du}{2}$$
##\int_{-1}^1 f(u) \frac{du}{2} ##
##\frac{1}{2}\int_{-1}^1 f(u) du = \frac{5}{2}##
Had an idea about the second exercise:
##u = f(x^2)##
##du = 2xf'(x^2)dx##
Thus
##\frac{1}{2}\int_{-2}^2 u2xdx##
##\frac{1}{2}\int_{-2}^2 udu##
The rest is trivial.
##du = 2dx##
Right.
Your notation needs some work, though. When you write "2.0" and "2.1" I think you intend that the "." is supposed to mean multiplication, but it looks like a decimal fraction. Use * to make this clearer.
##u = f(x^2)##
There's a much simpler substitution.
Thus
No this won't work.
The last integral is ##\frac{1}{2}\left. \frac{f(x^2)}{2} \right|_{x = -2}^2##
But you don't have any information about that function.
Oh, -_-'' I just noticed that I substituted f(x) by f'(x).
##u = x^2##
##du = 2xdx##
##\frac{1}{2}\int_{-2}^2 f(u) 2x dx \Rightarrow \frac{1}{2}\int_{-2}^2 f(u) du##
##\frac{1}{2}F(2) - \frac{1}{2}F(-2) \Rightarrow \frac{1}{2}F(2^2) - \frac{1}{2}F((-2)^2)##
I don't know the function ##f##, but the definite integral ended up being ##\frac{1}{2}F(4) - \frac{1}{2}F(4) = 0##.
##u = x^2##
##du = 2xdx##
That's what I get, as well, but your work is flaky here:
Nit: Don't use ##\Rightarrow## in place of =. Expressions that have the same value should be connected with =. The arrow (##\Rightarrow##) should be used between statements (typically equations or inequalities) where the statement on the left implies the statement on the right.
Besides that, how do you justify changing F(2) to F(22), and similar for F(-2) and F( (-2)2)?
The right way is to change the limits of integration to u values. When x = -2, u = ?, and when x = 2, u = ?.
FAQ: Calculate a definite integral from another definite integral
How do you calculate a definite integral from another definite integral?
To calculate a definite integral from another definite integral, you can use the substitution method or the integration by parts method. These methods involve substituting variables or using a specific formula to solve the integral.
What is the purpose of calculating a definite integral from another definite integral?
Calculating a definite integral from another definite integral can help simplify complex integrals and make them easier to solve. It can also help find the exact value of an integral that cannot be solved using basic integration techniques.
Can a definite integral be calculated from any other definite integral?
No, a definite integral can only be calculated from another definite integral if they have similar or related functions. For example, you can calculate the integral of (x^2 + 1) from the integral of x^2 by using the substitution method.
What are some common techniques used to calculate a definite integral from another definite integral?
Aside from the substitution and integration by parts methods, other common techniques include using trigonometric identities, partial fractions, and u-substitution.
Are there any limitations to calculating a definite integral from another definite integral?
Yes, there are limitations to this method of solving integrals. It may not be applicable to all functions, and it may not always result in a simplified or exact solution. In some cases, it may also require additional steps or techniques to fully solve the integral.
