mm874
- 7
A steam boiler produces steam at a rate of 0.5 kg.s-1. If the specific latent heat of vaporisation of water is 2.3 MJ kg-1:
The boiler has a steel plate which is 6mm thick. The thermal conductivity of steel is 48Wm/s k/s. Calculate the temp drop across the boiler plates if the area through which the heat is conducted is 5m^2?
Q/t=λ.A.(Change in temp/thickness)
48 x 5 x (change in temp/0.006)
