Calculate Deflection for Aluminium Tube Beam - Inertia, Mass & δ
In summary, the conversation discusses the calculation of deflection (δ) from a simply supported beam using the formula δ = F L³ ∕ 48 E I, where I represents the moment of inertia. The formula for the moment of inertia found online for a tube is 1/2 M (R1²+ R2²). The conversation also mentions the importance of cross-sectional shape in resisting bending and provides resources for further understanding of the concept of moment of inertia.
EddieC147
TL;DR Summary
Calculating Beam Deflection with Moment of Inertia and Mass
Hi There,
I am wanting to calculate the amount of deflection (δ) from a simply supported Beam. My Beam is an Aluminium Tube ø30mm with a 3mm Wall Thickness.
Force (F) - 500N
Length (L) - 610mm
Youngs Modulus (E) - 68 Gpa
Moment of Inertia (I) - ?
δ = F L³48 E I
Q1:
Is this the correct formula that I found online?
Q2: Put Simply why is the Moment of Inertia needed for this? ( I know this isn't relevant to solving the problem but I want to learn and understand)
Q3: What units should the Moment of inertia be measured into be entered into this formula?
The formula for the moment of inertia (I) of a tube I have found online is below.
Mass - M
Bore Radius - R1
Tube Radius - R2
I = 1/2 M (R1²+ R2²)
Q4: Is this the correct formula for finding the moment of inertia of a Hollow Tube?
Q5: What units should the Radius be measured into make the end unit match with Q3?
Q6: What units should the mass be measured into make the end unit match with Q3?
Finding the Mass needs the density of aluminium multiplied by the volume.
Q7: Do I need to multiply this by the volume of the full aluminium tube?
Any help is greatly appreciated.
Thanks
Ed
Welcome, Ed!
A tube does not make a very strong beam.
In order to resist bending, the cross-section of any beam should have as much material as possible, as far as possible from its neutral axis, on the same plane the bending forces and moments are being applied.
That is the reason for the shapes of the cross-sections of steel I-beams, H-beams and C-beams, as well as structural elements with square and rectangular closed sections.
Such shapes have a greater moment of inertia (the term is confusing) than circular or oval cross-sections of similar dimensions and wall thickness.
Please, see:
https://en.m.wikipedia.org/wiki/I-beam#Design_for_bending
https://en.m.wikipedia.org/wiki/Section_modulus
https://en.m.wikipedia.org/wiki/Second_moment_of_area
https://en.m.wikipedia.org/wiki/First_moment_of_area
Thanks for your input.
The Tube is not going to be used as a beam, just the beam bending calculation is the best way to represent the force that may act upon my Tube.
Likes Lnewqban
In this case, assuming that only the concentrated force in the middle is acting on the beam (ignoring self-weight), the maximum deflection will be: $$y_{max}=\frac{FL^{3}}{48EI}$$ where: $$I=\frac{\pi(D^{4}-d^{4})}{64}=\frac{\pi \cdot 30^{4} - 24^{4}}{64}=23474,765706 \ mm^{4}$$ Thus: $$y_{max}=\frac{500 \cdot 610^{3}}{48 \cdot 68000 \cdot 23474,765706}=1,48 \ mm$$
Here ##I## stands for area moment of inertia (also called second moment of area). It doesn't depend on the mass of the beam, only on its cross-sectional shape.
This video can help you understand the topic:
There's also one about the deflection but it discusses some advanced methods so try to get familiar with the concep of ##I## first.
  • Love
Likes EddieC147
Thanks for the reply, that is absolutely fantastic just what I wanted.
Thank you for your help
Likes berkeman and FEAnalyst
FAQ: Calculate Deflection for Aluminium Tube Beam - Inertia, Mass & δ
What is the formula for calculating deflection for an aluminium tube beam?
The formula for calculating deflection for an aluminium tube beam is: δ = (5/384) x (F x L^3) / (E x I), where δ is the deflection, F is the force applied, L is the length of the beam, E is the modulus of elasticity, and I is the moment of inertia.
How does the mass of the beam affect its deflection?
The mass of the beam does not directly affect its deflection. However, it does affect the force applied to the beam, which in turn affects the deflection. A heavier beam will require a greater force to cause the same amount of deflection as a lighter beam.
What is the moment of inertia and how does it impact deflection?
The moment of inertia is a measure of an object's resistance to changes in its rotational motion. In the case of an aluminium tube beam, a higher moment of inertia means that the beam is less likely to bend or deflect when a force is applied to it.
Can the deflection of an aluminium tube beam be reduced?
Yes, the deflection of an aluminium tube beam can be reduced by increasing its moment of inertia, decreasing its length, or increasing the modulus of elasticity. Additionally, proper design and reinforcement techniques can also help reduce deflection.
Are there any limitations to using this formula to calculate deflection?
Yes, there are some limitations to using this formula. It assumes that the beam is supported at both ends and that the load is applied at the center. It also does not take into account any external factors such as temperature, wind, or vibration, which can also affect the deflection of the beam.
