Calculate density of air from experiment.
In summary: The density of air is then calculated as the mass of the displaced air divided by the volume of the balloon.
spsa
A balloon filled with 0,78 liters of air is placed in liquid nitrogen. After a while the ball is taken out of the liquid nitrogen and weighed immediately, the mass is 2,27 grams. After the ball has grown to its regular size it weighs 1,26 grams.
What value does the experiment give as the density of air?
2,27-1,26= 1,01 grams (weight of contents)
1,01 grams = 0,00101 kg
0,78 L = 0,00078 m3
Density = mass/volume = 0,00101/0,00078 = 1,29 kg/m3
Will be very thankful for any/all help!
Hello spsa,
Welcome to Physics Forums!
0,78 L = 0,00078 m3
'Looks good to me! :approve:
(There are some approximations being made here, such as when the balloon has grown to its regular size, the temperature and pressure are the same inside and out. Although that's not absolutely true if the balloon maintains its elasticity, it should still give a very reasonable approximation.)
I think this method uses the buoyancy force to determine the density of air. It is assumed that the volume of the balloon is very small when it comes out of the nitrogen so that there is virtually no buoyancy. The difference in weight is then due to the bouyancy force it experiences once it is back to its original volume. So this method actually measures the mass of the air displaced by the volume of the balloon.
Related to Calculate density of air from experiment.
1. What is the formula for calculating the density of air?
The formula for calculating the density of air is mass divided by volume. In mathematical notation, it is written as ρ = m/v, where ρ is density, m is mass, and v is volume.
2. How do you measure the mass of air in an experiment?
In order to measure the mass of air in an experiment, you will need to use a balance scale. Place an empty container on one side of the scale and the container filled with air on the other side. The difference in weight between the two will give you the mass of the air.
3. How do you measure the volume of air in an experiment?
To measure the volume of air in an experiment, you can use a graduated cylinder or a syringe. Simply fill the cylinder or syringe with air and record the volume.
4. What are the units for density of air?
The units for density of air can vary depending on the system of measurement being used. In the International System of Units (SI), the unit for density is kilograms per cubic meter (kg/m³). In the US Customary System, the unit is pounds per cubic foot (lb/ft³).
5. How does temperature and pressure affect the density of air?
Temperature and pressure both have a significant effect on the density of air. As temperature increases, the molecules in the air move faster and spread out, resulting in a lower density. On the other hand, as pressure increases, the molecules are packed closer together, leading to a higher density. This relationship is known as the ideal gas law, which states that density is directly proportional to pressure and inversely proportional to temperature.
  • Classical Physics
