Calculate Diameter of Larger Piston Given 500N Force & 10cm^2 Area
  • Thread starter Thread starter bcddd214
    Pressure
To calculate the diameter of the larger piston in a hydraulic lift system, apply the principle of hydraulic pressure, which states that pressure is constant throughout the fluid. Given a force of 500 N on the smaller piston with an area of 10 cm², use the equation F_1/A_1 = F_2/A_2 to find the area of the larger piston. Once the area of the larger piston is determined, convert it to radius using A = πr², and then calculate the diameter with r = d/2. The problem emphasizes understanding the relationships between force, area, and pressure in hydraulic systems. This approach allows for an accurate determination of the larger piston’s diameter.
bcddd214
A hydraulic lift raises a 3000 kg car when 500 N force is applied to the smaller piston. If the smaller piston has an area of 10 〖cm〗^2, what is the diameter of the larger piston?
p_1=p_2
F_1/A_1 =F_2/A_2
A_2=(F_2 A_1)/F_2
A=πr^2
r=d/2
monkey/lightbulb=me from here
Do you know what all of your relevant equations mean? You have more than enough to solve the problem. Specifically, look at F_1/A_1 =F_2/A_2. Let's say that A_2 is the area of the smaller piston, 10 cm^2. You're trying to find A_1, because after that, you can easily get the diameter. What's F_2, the force on the smaller piston? How about F_1, the force on the larger piston?
The basic rule for this type of question is that pressure is constant at the same level. I think if the height of water level is the same, then it is fairly straight forward.
  • · Replies 23 ·
9K
10K
