Calculate Elastic Strain Energy in Solid State Physics
In summary: Good luck! In summary, the problem involves a thin film of ErAs grown on a GaAs substrate with a <001> orientation. The film is tetragonally distorted to match the substrate, resulting in stored elastic energy. To solve for the elastic strain energy per Er atom, you will need to use the elastic constants and the formula for elastic energy density. The in-plane stress can be calculated by setting the derivatives of the elastic energy density equal to zero. The "tetragonally distorted" structure refers to the film being stretched or compressed in one direction to match the substrate.
pzpzpzp
A think film of ErAs(rock salt structure, a=0.574nm) is grown on top of a thick GaAs (Zn-blend structure, a=0.565nm) substrate. The substrate orientation and the film growth direction are both <001>. For very thin films, the ErAs is tetragonally distorted such that its in-plane lattice constants match that of the substrate. This occurs in order to minimize the interfacial energy. Of course, there is also a price paid in terms of elastic strain energy.
Assume that the GaAs substrate is perfectly rigid and that the elastic constants (assume isotropic medium) of ErAs are C11=13*10E11[erg/cm^3] and C12=1.6*10E11[erg/cm^3]. Because there is no shear, the elastic energy density of the film is given by:
U=1/2{C11[εxx^2+εyy^2+εzz^2]+2C12[εxxεyy+εxxεzz+εyyεzz]}
a) what is the elastic strain energy(in eV) per Er atom?
b) What is te value of the in-plane stress?
At first, I thought it would be a simple plug-in-and-calculate question, but then I realize that I have no idea how to calculate all the ε's or where and how to find them. Nor do I know the units on those constants. Also, I can't imagine how ErAs "tetragonally distorted" looks like. Would someone help me please?
Thank you for your question. it is important to have a clear understanding of the context and parameters of a problem before attempting to solve it. Let's start by breaking down the information given in the forum post.
The problem involves a thin film of ErAs (erbium arsenide) grown on a GaAs (gallium arsenide) substrate. Both the substrate and film have a <001> orientation, meaning that their crystal axes are aligned in the same direction. This is important because it allows for the film to be tetragonally distorted, meaning that its lattice structure is stretched or compressed in one direction in order to match that of the substrate.
The elastic constants given (C11 and C12) are measures of the stiffness of a material. In this case, they represent the stiffness of ErAs and are given in units of erg/cm^3. These constants are used to calculate the elastic energy density (U) of the film, which is a measure of the energy stored in the film due to its deformation.
To answer part (a) of the question, you will need to calculate the elastic energy per ErAs atom. This can be done by dividing the elastic energy density (U) by the volume of one ErAs atom. The volume of an atom can be calculated using its lattice constant (a) and assuming a cubic unit cell (a^3). You will need to convert the units of the elastic constants from erg/cm^3 to eV/atom in order to get the final answer in eV.
For part (b) of the question, you will need to use the given formula for the elastic energy density (U) and solve for the in-plane stress (σ). This can be done by setting the derivatives of U with respect to εxx and εyy equal to zero and solving for σ. Again, you will need to convert the units of the elastic constants to get the final answer in eV.
As for the "tetragonally distorted" structure of ErAs, it means that the lattice structure of the film is stretched or compressed in one direction in order to match that of the substrate. This can be visualized as a square being stretched or compressed into a rectangle, with the other two sides remaining the same length.
I hope this helps you approach the problem with a better understanding. Remember to always break down the information given and use your knowledge of relevant concepts to guide your solution.
Related to Calculate Elastic Strain Energy in Solid State Physics
What is elastic strain energy?
Elastic strain energy is the energy stored in a material when it is deformed due to an external force. It is the potential energy that results from the stretching or compressing of the material's atomic bonds.
How is elastic strain energy calculated?
Elastic strain energy is calculated using the formula E = 1/2 * k * ΔL^2, where E is the strain energy, k is the material's spring constant, and ΔL is the change in length of the material.
What is the relationship between elastic strain energy and Young's modulus?
Young's modulus is a measure of the stiffness of a material, and it is directly related to elastic strain energy. The higher the Young's modulus of a material, the higher its elastic strain energy will be for a given amount of deformation.
How does temperature affect elastic strain energy?
As temperature increases, the atoms in a material have more thermal energy and can vibrate more, resulting in a decrease in elastic strain energy. This is because the bonds between the atoms are more easily stretched or compressed, leading to a decrease in the material's stiffness.
What is the significance of calculating elastic strain energy in solid state physics?
In solid state physics, elastic strain energy is important because it helps us understand the behavior of materials under stress and how they respond to external forces. It also plays a crucial role in determining the physical properties of materials, such as their strength and elasticity.
  • Atomic and Condensed Matter
  • STEM Academic Advising
