Calculate equilibrium dissolved oxygen at 19.8 Celsius
In summary, the equilibrium dissolved oxygen concentration for a temperature of 7°C when PO2 = 21% is 3.59x10-4 M. This is calculated using Henry's law and the Van 't Hoff equation to adjust the Henry's coefficient for O2 at 25°C.
spooky01
1. Calculate the equilibrium dissolved oxygen concentration for each temperature if PO2 = 21% (this means that if atmospheric pressure is 1 atm then O2 pressure is 21% of that)
K19.8/RT = Kp
PV=nRT
K19.8/RT = Kp
K19.8 = 1.475x10-3
(1.457x10-3)/(8.314x10-3)(273.15+19.8) = Kp
5.982x10-4 = Kp
Kp = (O2 (aq)) / (O2 (g))
5.982x10-4 = (O2 (aq)) / (0.21)
1.256x104 atm = O2 (aq)
ICE table:
__________________O2 (g)_______O2 (aq)
Initial______________0.21_________0
Change___________0.21 -x_______+x
Equilibrium_______0.21 -x_______+x5.982x10-4 = x/(0.21 – x)
5.982x10-4 (0.21 – x) = x
1.256x10-4 - 5.982x10-4 x = x
1.256x10-4 = x + 5.982x10-4 x
1.256x10-4 = 1.000598x
1.255x10-4 = x
PV = nRT
n/V = P/RT
M = 1.255x10-4 atm/(0.0821atm L/mol K) (273.15 + 19.8)
M = 5.218x10-6
This doesn't look right to me but I'm not sure what else to try. Thanks for the help!
No idea what is what of what, can you please post whole question and all information given?
Ok I'll simplify it a bit. All I need is how to calculate the equilibrium dissolved oxygen concentration for 7 degrees celsius if PO2 = 21% (this means that if atmospheric pressure is 1 atm then O2 pressure is 21% of that). K was previously found to be 1.813x10-3 at 7 degrees celsius. My professor is asking this so there must be a way! My head hurts. The chemical equation is O2 (g) = O2 (aq), that's it.
What is K specifically? How is it defined?
When it comes to solubility of gases, we typically describe it with Henry's law, not with a typical equilibrium constant. These are perfectly equivalent, but you need to be sure how K is defined and what units it has.
K is for concentration. So if I use Henry's law, Henry's coefficient for O2 at 25 degrees celsius is 1.3×10−3 mol L/atm. How can I adjust Henry's coefficient to work at 7 degrees celsius? Thanks for the help!
Huh? No idea what you just said.
Van 't Hoff equation comes to mind. Yes, it requires more data. But that's a general case - every approach will require some additional information that you have not listed so far.
Got it. Henry's law worked!
temp 7°C
ln(kHT/kH25) = (ΔH°/R)(1/298 – 1/T)
ln(kHT/1.26x10-3mol/Latm)=(-11.71kJ/mol/8.314x10-3kJ/molK)(1/298–1/280)
ln(kHT/1.26x10-3mol/Latm) = 3.04x10-1
e ln(kHT/1.26x10-3mol/Latm) = e3.04x10-1
kHT/1.26x10-3mol/L atm = 1.36
kHT = 1.71x10-3 mol/L atmC = (1.71x10-3 mol/L atm) 0.21atm
C = 3.59x10-4 M
FAQ: Calculate equilibrium dissolved oxygen at 19.8 Celsius
How is the equilibrium dissolved oxygen at 19.8 Celsius calculated?
The equilibrium dissolved oxygen at 19.8 Celsius is calculated using the Henry's Law equation, which states that the concentration of dissolved oxygen is proportional to the partial pressure of oxygen in the air above the water.
What is the significance of 19.8 Celsius in calculating equilibrium dissolved oxygen?
19.8 Celsius is the standard temperature at which water samples are tested for dissolved oxygen levels. This temperature is chosen because it is the average temperature of most natural water bodies.
What factors can affect the equilibrium dissolved oxygen at 19.8 Celsius?
The equilibrium dissolved oxygen at 19.8 Celsius can be affected by temperature, atmospheric pressure, and the presence of other dissolved gases such as carbon dioxide and nitrogen.
Can the equilibrium dissolved oxygen at 19.8 Celsius change over time?
Yes, the equilibrium dissolved oxygen at 19.8 Celsius can change over time due to changes in temperature, atmospheric pressure, and water quality. Human activities, such as pollution and changes in land use, can also affect the equilibrium dissolved oxygen levels in water bodies.
How is the equilibrium dissolved oxygen at 19.8 Celsius measured?
The equilibrium dissolved oxygen at 19.8 Celsius can be measured using a dissolved oxygen sensor, which measures the amount of oxygen in the water. This measurement is typically expressed in milligrams per liter (mg/L) or parts per million (ppm).
