Calculate exponential growth when rate r is changing
In summary, exponential growth is a process where a population or quantity increases at a constant rate over time, resulting in a steep curve. The formula for calculating exponential growth is A = P(1 + r)^t, with r representing the growth rate. A higher growth rate leads to a faster increase. If the growth rate is changing, the formula becomes more complex and needs to be calculated for each time period. Technically, exponential growth can continue infinitely, but in the real world, limiting factors cause it to reach a plateau and follow a logistic growth curve instead.
Vodkacannon
40
The formula f(t) = I(1 + r)t gives the value of something after it has grown for t years, at rate r, with an initial value I.
What if the growth rate r is continuously increasing?
What is the formula now?
Does it relate somehow to xx?
Mathematics news on Phys.org
It depends on how it increases with t. Is it linear with t? Geometric? Logarithmic? ...
It is, of course, [itex]f(t)= I(1+ r(t))^t[/itex]. And, yes, that has similar properties to [itex]x^x[/itex], especially if r(t) is linear.
Related to Calculate exponential growth when rate r is changing
1. What is exponential growth?
Exponential growth is a process in which the size of a population or quantity increases at a constant rate over a period of time. This results in a curve that becomes increasingly steep over time.
2. How is exponential growth calculated?
The formula for calculating exponential growth is A = P(1 + r)^t, where A is the final amount, P is the initial amount, r is the growth rate, and t is the time period.
3. What is the role of the growth rate in exponential growth?
The growth rate, represented by the variable r, is a measure of the speed at which the population or quantity is increasing. A higher growth rate leads to a steeper curve and faster growth.
4. What happens if the growth rate is changing in exponential growth?
If the growth rate is changing, the formula for calculating exponential growth becomes more complex. In this case, the growth rate would need to be calculated for each time period and the resulting values would be used in the formula for exponential growth.
5. Can exponential growth continue infinitely?
Technically, exponential growth can continue infinitely. However, in the real world, resources and other limiting factors eventually cause the growth rate to slow down and reach a plateau, resulting in a logistic growth curve instead of an exponential one.
  • General Math
  • General Math
  • Differential Equations
  • General Math
  • General Math
