Calculate force in english units
In summary, to determine the force needed to accelerate a 20 lbm mass at a rate of 60 ft/s^2 vertically upward, the equation F = m(g + a) can be used, where m is the mass in slugs and a is the acceleration in ft/s^2. It is important to note that in imperial units, weight is measured in pounds-force (lbf) and mass is measured in slugs, and there is a conversion factor of 1 lbf = 1/32.2 slug.
ENGR_student
Determine the force necessary to accelerate a mass of 20 lbm at a rate of 60 ft/s^2 vertically upward.
How do you properly account for weight?
What exactly is pound force?
How do you go from pound mass (lbm) to pound force (lbf)?
F - mg = ma
F = m(g + a)
Unfortunately This is how I would do it in SI units. However it is not correct in English units. I'm very confused on how it goes from pound mass to pound force
1 lbm is that amount of mass which, when accelerated at 32.174 ft/s^2, equals 1 lb force.
F = ma applies to all measurement systems with consistent units.
i understand that..but in the solutions. the equation was
F - 20 = (20/32.2)(60)
F=57
They took 20 on the left side to automatically be lbf even though it was originally lbm
Sorry to be pedantic but it is incorrect to call it "english units" as we in the UK use SI/metric units for almost everything. Only our road network and cars use miles, same as in the USA I think. The correct term would be "imperial units" (as opposed to metric units).
A one pound mass weighs one pound on planet Earth. Since weight is mg, a one pound mass is really 1/32 of a slug. The slug is the proper mass unit in the imperial system and must be used when using f= ma.
As PhantomJay indicated,
m (slugs) x a (ft/s2) = F (lbf)
1 lbm=(1/32.2) slug
Related to Calculate force in english units
What is force?
Force is a physical quantity that measures the interaction between two objects. It is a vector quantity, which means it has both magnitude and direction.
What is the English unit for force?
The English unit for force is pound-force (lbf). It is commonly used in the United States and is equivalent to approximately 4.45 newtons (N).
How do you calculate force in English units?
To calculate force in English units, you can use the formula: force (lbf) = mass (lb) x acceleration (ft/s^2). This formula is known as Newton's Second Law of Motion.
What is the conversion rate between pound-force and newtons?
1 pound-force (lbf) is equal to approximately 4.45 newtons (N). This conversion rate is commonly used when converting between English and metric units.
How is force measured in the English system?
Force is typically measured in pounds (lb) or ounces (oz) in the English system. These units are then converted to pound-force (lbf) using the conversion rate of 1 lbf = 1 lb.
14K
20K
