fyziksdunce
- 3
I'm trying to solve the frequency change due to gravity of a radio signal transmitted at 2x10^9 Hz from geosynchronous orbit (H = 35780 km). This (would be) easy if I could use the value g = 9.8m/s^2, the catch is "do not assume constant g".
The equation assuming constant g is:
(f_rec - f_trans)/f_rec = gH/c^2 (Eq 1)
(Note this is the form derived from the original energy conservation relation: hf = hf' + mgH, use m=E/c^2=hf/c^2).
My initial stab at it was to substitute an expression using the universal gravitational constant:
(f_rec - f_trans)/f_rec = (GM)*(1/r_earth - 1/(r_earth + H))/(c^2) (Eq 2)
where M is the mass of the Earth and G is the universal gravitational constant. This results in a frequency shift of ~+1 Hz (so small I needed to use a num2str command in MATLAB to see it given the magnitude of f_trans).
I then thought perhaps I was being cute with assuming H and an inverse distance would cancel w/o deleterious effects, so I went back to the unsimplified form:
(f_rec - f_trans)/f_rec = (GMH)*(1/r_earth - 1/(r_earth + H))^2/(c^2) (Eq 3)
This yielded a frequency shift of ~+5 Hz (again so small I needed to use a num2str command in MATLAB to see it given the magnitude of f_trans).
My issue is that I'm not sure I'm accounting for non-constant gravity correctly; if I am then I've solved the problem, if not...
Please forgive if this is an easy problem or there is a "well-known" treatment for non-constant gravity I am just not finding, I am a mathematician with only a high school physics background taking a masters level physics class.
Thanks for the help.
