Calculate how much force you would have to apply to crate?
In summary: Hope that helps!In summary, according to the problem statement, you need to calculate the force required to push a crate up a ramp, and account for the effects of static and kinetic friction.
HaileyY
Calculate how much force you would have to apply to the crate to get it to go at constant speed up a 30 degree ramp.
Using kinetic friction for equation.
I couldn't find the formula for kinetic friction which also includes calculating force with an angle. Anyone know the correct formula/equation to use?
Hi HaileyY, Welcome to Physics Forums.
Is that the entire problem statement? No other information given? If it is then it doesn't look like you need to consider friction. Just assume that the ramp is smooth and frictionless.
There's two different "types" of friction: static (also known as "standing") friction and kinetic (aka "moving") friction. Since your problem says to use kinetic friction (which is almost always less than static friction) then there must be some way for you to look that up - maybe a table in your book or an earlier problem. The force required is to counteract the friction. Pushing a crate up an incline requires you to do the work of raising the crate, mgh, and of countering the normal force of friction. Friction is computed using the component of force perpendicular to the inclined surface, so you have to do a force diagram. (Look at it this way: if the incline was 90°degrees then there would be 0 force required to overcome friction (since gravity, the only force involved by assumption, CAN'T act perpendicular to the downward direction, so there's no friction) while if the inclined surface was 0° (which means flat, horizontal) the force would be 100% of the crate's weight times the friction coefficient. So, what trig function is zero at 90° and 1 at 0°? The formula has to include weight * function_of_(angle) * friction_coefficient. As is, (originally), your problem doesn't have enough information..hint: the trig function is going to be sine or cosine. You need to know how both behave at 0, 90°, 180° and 270° since picking which to use will be a common enough problem...memorizing formulas will only get you so far (but perhaps far as you want to go, haha). so anyway there will be two forces to counter-act: the force of gravity (the weight) and the force of friction (which is related to both weight and surface friction). But you should know how a wedge helps you lift objects, so that force should be easy. And friction is always considered to be normal (perpendicular) to the surface on which the object is moving (in this case the surface is inclined). So you always (when friction is involved) need to be able to compute that normal force given the inclination to the Earth (and the weight of the object (and the coefficient of friction)).
Related to Calculate how much force you would have to apply to crate?
1. How do you calculate the force needed to move a crate?
To calculate the force needed to move a crate, you will need to know the mass of the crate and the acceleration due to gravity. The formula for force is F=ma, where F is force, m is mass, and a is acceleration. So, you would need to multiply the mass of the crate by the acceleration due to gravity to get the force needed to move it.
2. What units of measurement should I use to calculate the force needed to move a crate?
The standard units of measurement for force are newtons (N). However, if you are using the imperial system, you can also use pounds (lbs). Just make sure to convert your units consistently throughout the calculation.
3. Does the surface the crate is being moved on affect the force needed?
Yes, the surface the crate is being moved on can affect the force needed. For example, if the crate is being moved on a smooth surface with little friction, less force will be needed compared to moving the crate on a rough surface with more friction.
4. Can you calculate the force needed if the crate is being moved at an angle?
Yes, you can still calculate the force needed if the crate is being moved at an angle. In this case, you would need to use trigonometry to calculate the horizontal and vertical components of the force. The horizontal component would be used to move the crate, while the vertical component would be used to counteract the force of gravity.
5. Are there any other factors that can affect the force needed to move a crate?
Yes, there are other factors that can affect the force needed to move a crate. These can include the shape and size of the crate, the coefficient of friction between the crate and the surface it is being moved on, and any external forces acting on the crate, such as wind or inclines.
