Calculate integral through a change of variables
In summary, the problem involves calculating the integral of e^{-(x+y)^4}(x^2-y^2) over the domain D, which is defined as {(x,y) \in \mathbb{R}^2 : x+y < 1; 0 < y < x}. The attempt at a solution involved a substitution of u=x+y and v=x-y, leading to a simpler integral of e^{u^4}uv. However, there was a mistake in the limits of integration for v, which should be v=u and v=1. The correct Jacobian for this substitution is 1/2.
tsuwal
105
Let
[itex]
D=\{ (x,y)\in\mathbb{R}^2:x+y< 1;0< y< x\}
[/itex]
calculate [itex] \int_{D} e^{-(x+y)^4}(x^2-y^2) [/itex]through an appropriate change of variables
[itex] \int_{D} f *dxdy=\int_{D} f*Jacobian*dudv [/itex]
I've tried x+y=u and x-y=v which is a linear transformation so the jacobian is constant. However the integral becomes pretty ugly meanwhile and I can't solve it. What do i do?
Try something more like
u=x+y
v=x
On the contrary, with that substitution, the integral becomes very nice! With u= x+ y. [itex]e^{-(x+y)^4}= e^{u^4}[/itex] and with, also, v= x- y, [itex]x^2- y^2= (x- y)(x+ y)= uv[/itex] so the integrand becomes [itex]e^{u^4}uv[/itex]. Of course, the boundaries, x+y= 1, y= 0, and y= x, in the u, v system, become u= 1, v= 0, and u= v. The integral is
[tex]2\int_0^1\int_0^u e^{-u^4}uv dvdu[/tex]
Now, do the first, very easy, integral with respect to v and then slap your forehead and cry "Of course"!
yeah right, did a mistake on the limits of integration of the v variable. I calculated the limiting points of the triangle in the uv plane and did a mistake in one point. Limits of v became v=u and v=1. This way was impossible.
Thanks but I think you did a mistake on the Jacobian. It is 1/2 not 2.
FAQ: Calculate integral through a change of variables
What is a change of variables in integration?
A change of variables in integration is a technique used to simplify the calculation of integrals by replacing the variable of integration with a new variable. This new variable is typically chosen to make the integral easier to evaluate.
How do you perform a change of variables in integration?
To perform a change of variables in integration, you need to follow these steps:
1. Identify the original variable of integration.
2. Choose a new variable and set up an equation to relate it to the original variable.
3. Rewrite the integral in terms of the new variable.
4. Calculate the new limits of integration using the equation from step 2.
5. Evaluate the integral using the new variable and limits of integration.
What is the purpose of using a change of variables in integration?
The purpose of using a change of variables in integration is to simplify the integral and make it easier to evaluate. This can be especially helpful when dealing with complex integrals, as it allows us to transform the integral into a more manageable form.
What types of integrals can be solved using a change of variables?
A change of variables can be used to solve a variety of integrals, including trigonometric, exponential, and logarithmic integrals. It is also commonly used in multivariable calculus to evaluate double and triple integrals.
Are there any limitations or restrictions when using a change of variables in integration?
Yes, there are limitations and restrictions when using a change of variables in integration. The chosen new variable must be a one-to-one function of the original variable, and the limits of integration must also be transformed correctly. Additionally, some integrals may not be solvable using a change of variables, and in some cases, it may actually make the integral more difficult to evaluate.
