Calculate iron container acceleration in railgun system on the Moon
In summary, the conversation discusses how to calculate the required voltage and current for a cylindrical iron container in a vertical railgun system on the Moon's surface. The container has a wall thickness of 20 cm and a total weight of 500 tons when filled with cargo. The exit acceleration is desired to be 2km/s² and the gravitational acceleration is 1.65km/s². The goal is for the container to reach a height of 300km and be captured by another spacecraft. The expert mentions that the current required for this task would be astronomical, as it was previously only a few pounds and 5 megaamperes were needed for 6 km/s. The conversation also considers if there is a way to calculate the
PlanetGazer8350
Having a cylindrical iron container with wall thickness of 20 cm, and a total weight of 500 tons when filled with its cargo, how would you be able to calculate its required voltage and current input in a vertical railgun system (relative to the Moon's surface), with an exit acceleration of 2km/s², for example? The gravitational acceleration would be 1.65km/s², pulling the cylinder due to its gravity. It should then, at an specific height, for example, 300km, meet with another spacecraft (in an elliptical orbit), just before its aphelion, with the cylinder and spacecraft having a very near velocity. Exactly what exit acceleration should be required for the cylinder to be able to reach the 300kms of height, when it is already starting to decelerate, for it to be captured by that spacecraft (the previous 2km/s² being just an example for that situation)?
The current required will be out of this world in the strictest sense. Some years ago (like 15) when I was involved with rail guns, the objects being accelerated were a few pounds at most, and the currents were around 5 megaamperes to obtain about 6 km/s. Your 500 ton mass is going to require an exorbitant amount of current to reach the speeds you want.
Likes berkeman
I already knew that the required current would be astronomical, but is there exactly any way of calculating the current with a formula? Or, in the other hand, calculate the acceleration with an specific current and voltage input (not in the previous case, but in a different, for example, 5 kilograms)?
The attached PDF describes a good bit about the modeling and simulation of a rail gun. While it is dated, the basics have to remain unchanged.
  • CompulsatorModeling.pdf
Related to Calculate iron container acceleration in railgun system on the Moon
1. How does the acceleration of an iron container in a railgun system on the Moon differ from Earth?
The acceleration of an iron container in a railgun system on the Moon is significantly higher than on Earth. This is due to the Moon's lower gravity, which is about 1/6th of Earth's gravity. As a result, the iron container will experience a much greater acceleration and reach higher velocities in a railgun system on the Moon.
2. What is the formula for calculating the acceleration of an iron container in a railgun system on the Moon?
The formula for calculating acceleration is a = F/m, where "a" is acceleration, "F" is the force applied, and "m" is the mass of the object. In the case of a railgun system on the Moon, the acceleration can also be affected by the Moon's gravity and the resistance of the railgun system itself.
3. How does the mass of the iron container affect its acceleration in a railgun system on the Moon?
The mass of the iron container plays a significant role in its acceleration in a railgun system on the Moon. The greater the mass of the container, the more force will be required to accelerate it. This means that a heavier iron container will experience a lower acceleration than a lighter one in the same railgun system on the Moon.
4. Are there any other factors that can affect the acceleration of an iron container in a railgun system on the Moon?
Yes, there are other factors that can affect the acceleration of an iron container in a railgun system on the Moon. These include the resistance of the railgun system, the strength of the magnetic field, and the efficiency of the system in converting electrical energy into kinetic energy. These factors can vary depending on the design and materials used in the railgun system.
5. How does the acceleration of an iron container in a railgun system on the Moon impact its final velocity?
The acceleration of an iron container in a railgun system on the Moon directly affects its final velocity. As the container experiences a higher acceleration, it will reach higher velocities in a shorter amount of time. This can be beneficial for launching objects into space from the Moon's surface, where the lower gravity allows for higher velocities and less fuel consumption.
  • Astronomy and Astrophysics
