Calculate Load carrying capacity of vertically mounted suction cup
The discussion focuses on calculating the load-carrying capacity of a vertically mounted suction cup with a diameter of 90mm, mounted on glass, under specific pressure conditions. Two approaches to the calculation are presented: one based on force equilibrium and friction, yielding a maximum load of approximately 1.2 kg, and another considering the moment acting on the suction cup, suggesting a load of about 3.8 kg. Additional calculations indicate that the suction cup will slide down the glass at a load of 3.24 kg and will break off the surface at approximately 4.87 kg. The coefficient of friction between the suction cup and glass is assumed to be 0.2. The discussion concludes with a confirmation that the approaches used are valid for understanding suction cup design and load capacity.
Acenish
TL;DR Summary
I'm looking for means of calculating load carrying capacity of a vertically mounted suction cup.
Suction Cup effective diameter = 90mm
Mounted on a vertical glass surface
Pressure inside the suction cup = 0.75bar
Pressure difference = 0.25bar
Weight is suspended from a rod attached in the centre of the suction cup.
Rod length = 150mm
Need to calculate how much weight can be suspended before the suction cup pulls off the glass surface
Assume, coefficient of friction between suction cup and glass as 0.2
Welcome to PF.
Is this a homework problem?
Have you tried to solve the problem yourself?
Hi
No its not a homework problem, rather a curiosity in suction cup design and load capacity.
This arose while using suction cup phone mounts or clothes line as well as with respect to nerf arrows.
Below is a diagram of the suction cup with a suspended load.
Applying force equilibrium, we get
Fsuction = N (normal force)
Ffric = W (load)
now, Ffric = µ x N = µ x Fsuction
& Fsuction = ΔP x A
so, Ffric = µ x ΔP x A = W
Assume, µ = 0.1
Patm =1 bar (0.1N/mm²)
Pi = 0.8bar (0.08N/mm²)
A = π x d² /4 = 6361.73mm² (d = 90mm)
thus, W = 0.1 x (0.1 - 0.08) x 6361.73 = 12.72N = 1.2kg (approx)
However, what has me puzzled is that the Load W will also have a moment acting on the suction cup and this moment if considered in the centre of the cup, will be balanced by the Fsuction till it fails under a 'peeling-off' action (in this case the top end will peel as W is acting downwards.
This gives, W x 150mm = Fsuction x 45 (radius of cup)....... considering moment in the centre.
=> W = (ΔP x π x d² /4) x 45 / 150 = 38.17 N = 3.8kg (approx)
Was hoping to get feedback on whether either of the approaches are correct.
Thanks
The cup could unstick from the glass, or it could slide down the glass.
Area of cup = Pi*(0.045)^2 = 6.36e-3
Differential pressure = 0.25 bar * 100 kPa/bar = 25 kPa
Cup force against wall = area * pressure = 159 N.
At what vertical load will the cup slide down the wall?
Note that it is independent of the rod lever arm length.
Apply friction; 159 N * 0.2 = 31.8 N.
31.8 / 9.8 = 3.24 kg.
If it did not slide, the cup would break off the surface at;
Assume the length of the rod is measured from the glass.
Fvert = 159 N * (45 mm / 150 mm) = 47.7 N.
47.7 / 9.8 = 4.867 kg.
So the cup will slide at 3.24 kg.
Acenish said:
Assume, µ = 0.1
Thanks for response.
Values are arbitrary and I am interested in the approach.
Glad to know, I wasn't off the mark!
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
