Calculate mass of NaHCO3 when losing CO2 in experiement
In summary: So thanks again!In summary, the class conducted an experiment with 1.99 grams of NaHCO3 and 10.13 grams of HCl, resulting in 11.77 grams of the final product and 0.35 grams of CO2 "lost." The attempt at solving the questions involved using the 0.35 grams of CO2 to calculate the mass of NaHCO3 used (0.6682 g) and assuming that NaHCO3 was the limiting reactant. However, it was later realized that HCl was actually the limiting reactant and that the initial assumption of starting with 10.17 grams of HCl was incorrect. The final solution was calculated to have a concentration of 0.
ptownbro
60
We have a homework problem that we are not sure is right. Need some help.
The class ran an experiment where they were given 1.99 grams of NaHCO3 and 10.13 grams of HCl to create NaCl, H2O, and CO2. Before starting the experiment, what they were given weighed 12.12 grams in a beaker (which adds up to the 1.99g + 10.13g given, so that makes sense). However, after the experiment was ran, they ended up with 11.77 grams of the final product. They were told that the 0.35 grams was "lost" as CO2.
Here are the questions.
a) Calculate the mass of NaHCO3 used.
b) Calculate the % yield.
NaHCO3 + HCl = NaCl + H2O + CO2.
In our attempt to answer the questions, we first assumed the 11.77 grams only related to the NaCl + H2O part of the above equation and that the 0.35 grams relates to the CO2. Even though they say it was "lost" that just means it wasn't captured in the beaker - it's not really lost. What's left in the beaker, and what they can weigh, is just the NaCl + H2O which weights 11.77 grams.
Given that, we can use the 0.35 grams of CO2 to calculate the grams of NaHCO3 (using conversions and ratios).
a) The mass of NaHCO3 would be: We think it's 0.6682 g, but need help confirming.
0.35 g CO2 x ( 1 mole CO2 / 44 g CO2 ) x ( 84 g NaHCO3 / 1 mol NaHCO3) = 0.6682 g NaHCO3
b) The % yield would be: Not sure. Need help answering and understanding
We assumed the NaHCO3 is the limiting reactant, because at 10.13 grams of HCl would require 23.6 grams of NaHCO3 in a balanced equation (we got that by 10.13 x 1/36 x 84). Since we only have 1.99 grams of NaHCO3 that limits the HCl to 0.833 grams and the rest is excess.
However, where we got confused is if there is excess NaHCO3, where is it in the right side of the equation? Wouldn't there be a certain amount leftover there?
ptownbro said:
0.6682 g NaHCO3
Yes, that's the amount of NaHCO3 required to produce 0.35 g of CO2.
It is not on the right side of the equation as the equation describes only the reaction- it doesn't say anything about things that didn't react.
There is a problem with the question though. How do you weight a total of 12.12 g in the beaker, it the reaction starts the moment things are mixed? You need some time to weight them, before you end the procedure, a lot of CO2 is already lost, as the reaction - especially initially - is quite vigorous.
Also, you didn't start with 10.17 g of HCl. It was 10.17 g of the HCl solution of unknown HCl concentration. Not knowing how much HCl was there you can't calculate % yield. You can calculate what fraction of the NaHCO3 reacted producing CO2, but this is not the % yield.
Ah. Excellent. Makes sense. Thanks.
Yes. You're right. I was not in class room when expirement was done (this is for my daughter). So I described that detail wrong. I confirmed with her that this was done separately.
Hmm. Not sure what you mean here. Isnt the HCL is the solvent?
Also was my logic about the limiting reactant and its amount correct
No. Hydrochloric acid - as used in labs - is just a water solution of HCl. In "normal" conditions (pressure and temperature like the ones we typically deal with, sometimes called RTP - room temperature and pressure) HCl is a gas. Nasty gas.
As far as I an tell they were correct in terms of your understanding of what the limiting reagent is, but incorrect as they were based on incorrect assumptions about the amount of HCl. As you have calculated the amount of NaHCO3 that reacted to be 0.67 g, apparently it was in excess and it was hydrochloric acid that was a limiting reagent. Using this information it is not difficult to calculate the concentration of HCl to be 0.8 M and it is a reasonable value for a school lab experiment - concentrated enough to be still a valuable reagent for simple experiments, diluted enough to be quite safe.
Likes ptownbro
Ok. Thanks so much for your help. We'll try to figure it out from here. Unfortunately her teacher isn't the best at providing help and doesn't provide the final answer for homework so we don't always know if we are actually on right track with our logic.
Related to Calculate mass of NaHCO3 when losing CO2 in experiement
1. How do you calculate the mass of NaHCO3 when losing CO2 in an experiment?
The mass of NaHCO3 can be calculated by using the following formula: Mass of NaHCO3 = Mass of the original sample - Mass of the remaining sample after CO2 loss.
2. What is the purpose of calculating the mass of NaHCO3 in this experiment?
The purpose of calculating the mass of NaHCO3 is to determine the amount of CO2 that was lost during the experiment. This can provide information about the reaction that took place and the efficiency of the process.
3. How can the mass of the remaining sample be measured accurately?
The mass of the remaining sample can be measured accurately by using a balance or scale with a high precision. It is important to ensure that the balance is properly calibrated and that the sample is placed carefully on the scale to avoid any errors in measurement.
4. Is there a specific unit for expressing the mass of NaHCO3?
Yes, the mass of NaHCO3 is typically expressed in grams (g) or milligrams (mg). These units are commonly used in scientific experiments and are easily converted between each other.
5. What factors can affect the accuracy of the calculated mass of NaHCO3?
The accuracy of the calculated mass of NaHCO3 can be affected by factors such as human error in measurement, improper calibration of the balance, and any external factors that may have influenced the experiment (e.g. temperature changes). It is important to carefully control these variables to obtain accurate results.
11K
9K
