Calculate number microstates? Why not include acceleration?
In summary, the conversation discusses the calculation of microstates in a system of indistinguishable particles in a 3D box. Some examples use positions and velocities to represent microstates, but in relativistic theory, the interaction of particles cannot be described by ordinary differential equations. Instead, the state of a system of interacting particles is given by their positions and momenta, which cannot be determined solely from these variables. The use of higher derivatives and relativity theory complicates this calculation.
llisuhrtgslir
I want to calculate the number of microstates in a system for, say, n indistinguishable particles in a 3D box. Some examples I see just represent one microstate as a list of positions. Other examples use a list of positions and a list of velocities (translational and rotational). And if you're supposed to use position and velocity, why not acceleration too? I can maybe see why you wouldn't use "jerk" and fifth derivatives of position and so on.
Because the state of such is system is completely described by the canonical coordinates of the particles. Specifying the position and momentum of all the particles uniquely locates it in phase space.
Those examples work within Newtonian statistical physics, where the state of many-particle system is specified by stating coordinates and their first derivatives. Higher derivatives are then determined by the equations of motion.
This is not valid in relativistic theory, where the interaction of the particles is no longer describable by such ordinary differential equations.
The acceleration on each particle is calculated from the force on the particles, which you can determine from a snapshot of the system, whereas the velocity is just a free parameter.
States of individual particles of a system in classical relativistic stat mech are given (in flat space-time) by the phase space of 4-positions and 4-momenta with the latter constrained to lie on the mass hyperboloid so it isn't much different from the Newtonian case.
Only if the particles are non-interacting. State of a system of interacting particles in relativistic theory is not specified by their positions and momenta only, because forces acting on them cannot be functions of the positions and momenta only.
Let's wait for the OP to come back before going into the intricacies of relativity theory. As the question was posed, no relativity theory was needed, so let us keep it nice and elementary.
Related to Calculate number microstates? Why not include acceleration?
What is the concept of number microstates?
The concept of number microstates is a fundamental concept in statistical mechanics and thermodynamics. It refers to the number of possible ways that a system can be arranged or configured, given its energy and other properties.
How do you calculate the number of microstates?
The number of microstates can be calculated using the formula W = N!, where N is the number of particles in the system. This formula assumes that all particles are distinguishable and can be arranged in any order.
Why is it important to calculate the number of microstates?
Calculating the number of microstates is important because it allows us to determine the entropy and other thermodynamic properties of a system. It also helps us understand the behavior of systems at the microscopic level and make predictions about their macroscopic behavior.
How does the number of microstates relate to entropy?
The number of microstates is directly related to entropy, which is a measure of the disorder or randomness of a system. As the number of microstates increases, so does the entropy. This means that a system with more possible arrangements has a higher entropy and is more disordered.
Why is acceleration not included in the calculation of number microstates?
Acceleration is not included in the calculation of number microstates because it is not a property that affects the arrangement or configuration of a system. The number of microstates is determined by the system's energy and other properties, such as temperature and volume. Acceleration is a measure of how quickly the system's properties are changing, but it does not affect the number of possible arrangements.
