Calculate numerically the area
  • MHB
  • Thread starter mathmari
  • Tags
    Area
In summary, The functions f(x)=1/3(x-2)^2e^{x/3} and p(x)=-2/3x+4/3 have two real intersection points at x=0 and x=2. The area between the graphs of these two functions can be calculated numerically, and the best method for this case would be the trapezoidal rule.
mathmari
MHB
5,049
Hey! :eek:
The functions \begin{equation*}f(x)=\frac{1}{3}(x-2)^2e^{x/3} \ \text{ and } \ p(x)=-\frac{2}{3}x+\frac{4}{3}\end{equation*} have exactly two real intersection points at the region $x\geq 0$.
Calculate numerically the area that is between the graphs of these two functions, with accuracy of two decimal digits. For that do we have to claulate numerically the intersections points, using for example Newton's methos? (Wondering)
Mathematics news on Phys.org
Hey mathmari!
We could, but perhaps the intersection points are "nice" points.
What are the potentially nice points? (Wondering)
You mean checking it from the graph? Then we have the intersection points $x=0$ and $x=2$, right? (Wondering)
That works. (Nod)
Note that $f(x)=\frac{1}{3}(x-2)^2e^{x/3}$ is hard to match with a line, since it has an exponential function in it.
However, there are 2 special cases.
1. When $(x-2)=0$ the function is zero because the polynomial factor is zero.
2. When $x=0$ the exponential function is $1$.
Turns out that those specials cases coincide with the points of intersection. (Thinking)
That works. (Nod)
So this is an other approach to give the intersection points, isn't? (Wondering)
To calculate numerically the area is referring to a numerical integration method and not a numerical method to find the roots, right? (Wondering)
Yep. (Nod)
I think Klaas Vanaarsen's point was that there are not many values that will make an exponential and a polynomial the same. But one would be to make the coefficient of the exponential 0 so the exponential disappears. The coefficient is x- 2 so we try x= 2 and find that it works. The other is the value x= 0 because then [tex]e^{x/2}= e^0= 1[/tex], an easy number!
Ok! I got it so far! (Yes)
Which is the best numerical integration method for this case? (Wondering)
Looks like a case for the trapezoidal rule. (Thinking)
FAQ: Calculate numerically the area
What is numerical calculation of area?
Numerical calculation of area is the process of finding the size of a two-dimensional shape by using numerical values and mathematical operations.
What are the steps involved in calculating the area numerically?
The steps involved in calculating the area numerically include: 1) identifying the shape and its dimensions, 2) choosing a numerical method (such as integration or approximation), 3) breaking the shape into smaller parts if necessary, 4) calculating the area of each part, and 5) summing up the areas to get the total area.
What is the difference between numerical and analytical calculation of area?
Numerical calculation of area involves using numerical methods and approximations to find the area, while analytical calculation involves using precise mathematical equations and formulas to find the exact area.
What are some common numerical methods used to calculate area?
Some common numerical methods used to calculate area include the trapezoidal rule, Simpson's rule, and Monte Carlo method.
What are some applications of numerical calculation of area in science?
Numerical calculation of area is used in various scientific fields such as physics, engineering, and biology. It is used to find the area under a curve, calculate the volume of irregular shapes, and determine the surface area of complex objects, among other applications.
11K
