Calculate Pressure at Bottom of Water Tank: Ans 1. 3.58 bar
  • Thread starter dr hunter
  • Tags
    Pressure
In summary, we are solving for the height of the water and pressure of the air when the pressure of the water at the hole is equal to atmospheric pressure. By setting up the equation Pwater = rho*g*h + Patm and substituting in the known values, we can solve for h and find that the height of the water is 0.0002 m. This may be a very small height due to rounding errors, but it will continue to decrease as the water flows out of the tank.
dr hunter
A cylindrical storage tank, 5m in diameter and 8m high is partially filled with water.
[The tank is partially filled with water to 6m height, sealed from the atmosphere and has air at 3 bar absolute pressure for the remaining 2m height.
1.Calculate Pabs at bottom of tank (in bar)
2. Water leaks due to hole in bottom of tank causing water level to fall. Pabs & V are related by pV=C, calculate height of water when air Pabs=Patm.
3. Water flows until pressure of water at hole = Patm then flow reduces. calculate water height & Pabs of air when this condition occurs.
ANS 1. 3.58 bar, 2. 2m, 3. 1.2m & 0.882 bar.
thanks in advance for any help given I am stuck on part 3 and have this so far:
1. P2 - P1 = rho g h
Pwater = rho g h + Pair = 1000*9.81*6 + 3*10^5 = 3.58 bar.
2. P1V1=P2V2 so
V2 = P1V1/P2 = 3*10^5 * 2 * pi * 2.5^2 / 10^5 = 117.81m^3 so
h = V / pi * r^2 = 117.81 / pi * 2.5^2 = 6m so
Hwater = Htank - Hair = 8-6= 2m
3. Totally stuck, I tried new Pwater = rho g h + Patm = 1000*9.81*2 + 1bar = 1.2 bar
then V2 = P1*V1 / P2 = 1.2 *10^5 * 2*pi*2.5^2 / 10^5 = 47.124
giving 2.4m height (exactly 2x wrong)
Thanks again for any help
given
Hello,
Thank you for sharing your progress so far. Let's take a closer look at part 3 and see if we can figure out where the issue may be.
For part 3, we need to find the height of the water when the pressure of the water at the hole is equal to atmospheric pressure (Patm). This means that the pressure at the bottom of the tank (Pwater) will also be equal to atmospheric pressure. So, we can set up the equation as:
We know that Pwater is equal to 3.58 bar from part 1, so we can substitute that in:
3.58 = rho*g*h + Patm
We also know that Patm is equal to 1 bar, so we can substitute that in as well:
3.58 = rho*g*h + 1
Now we just need to solve for h. Rearranging the equation, we get:
h = (3.58 - 1) / (rho*g)
We can calculate rho*g by multiplying the density of water (1000 kg/m^3) by the acceleration due to gravity (9.81 m/s^2):
rho*g = 1000 * 9.81 = 9810
Substituting this into the equation, we get:
h = (3.58 - 1) / 9810
h = 0.0002 m
So, the height of the water when the pressure is equal to atmospheric pressure is 0.0002 m. This is a very small height, so it is possible that there may be some rounding errors in your calculations. However, it is important to note that the height of the water will continue to decrease as it flows out of the tank, and the pressure will also decrease accordingly.
I hope this helps! Let me know if you have any further questions or if you need clarification on any of the steps. Good luck with your calculations!
FAQ: Calculate Pressure at Bottom of Water Tank: Ans 1. 3.58 bar
1. What is the formula for calculating pressure at the bottom of a water tank?
The formula for calculating pressure at the bottom of a water tank is P = ρgh, where P is the pressure, ρ is the density of the liquid (in this case, water), g is the acceleration due to gravity, and h is the height of the liquid column.
2. What is the unit of measurement for pressure at the bottom of a water tank?
The unit of measurement for pressure at the bottom of a water tank is typically expressed in pascals (Pa) or bar (1 bar = 100,000 Pa).
3. How do you convert the pressure at the bottom of a water tank from bar to psi?
To convert the pressure at the bottom of a water tank from bar to psi (pounds per square inch), you can use the conversion factor 1 bar = 14.5038 psi. Simply multiply the pressure in bar by 14.5038 to get the equivalent value in psi.
4. What factors can affect the pressure at the bottom of a water tank?
The pressure at the bottom of a water tank can be affected by several factors, including the height of the liquid column, the density of the liquid, the acceleration due to gravity, and any external forces acting on the liquid (such as air pressure or temperature changes).
5. How does the pressure at the bottom of a water tank change if the tank is filled with a different liquid?
The pressure at the bottom of a water tank will vary depending on the density of the liquid. A denser liquid will result in a higher pressure, while a less dense liquid will result in a lower pressure. The formula for calculating pressure (P = ρgh) can be used to determine the pressure at the bottom of a water tank filled with a different liquid, as long as the height of the liquid column and acceleration due to gravity remain the same.
18K
