Calculate pump height by using the Bernoulli Equation
In summary: Hmax = 0.2201 - 4m + 0.0809 metersIn summary, the pump manufacturer has given NPSH = (Ps - Pvp)/qg and provided Darcys friction equation.
sci0x
83
A centrifugal pump has an NPSH of 4 metres. It is used to transfer hot wort from kettle, open to atm prsssure, to a whirlpool. Calculate the minimum vertical distance the pump must be positioned below the outlet of the kettle to enable effecient pump operation.
Wort flow rate is 200 hl h-1
Vapour pressure of wort at 100 degrees C = 99 kPa
Wort density = 1065 kg m-3
Pipe length from kettle to pump inlet = 8.5 m
Pipe internal diameter = 75 mm
Pipe friction factor = 0.002
Acc due to grav = 9.81 m s-2
Atm pressure = 101.3 kPa
Darcys Friction Equation
Bernouilli Equation
Really need to help getting started with this one.
They've given NPSH = (Ps - Pvp)/qg
Where Ps = Suction pressure at pump inlet
Pvp = vapour pressure of liquid at temp of pumping
q = density of liquid
g = acc due to grav
They've also provided Darcys friction Equation
The examiners tip (its a past exam paper) said that people used equations that enable fast solutions, but expected way was Bernouilli Eq.
Bernouilli Eq:
P2/q + (V2^2)/2 + gz2 = P1/q + (V1^2)/2 + gz1
So P2 is 99,000 Pa
q = 1065 kg m-3
V2 is 200 hl h-1 = 5.5x10^-3 m3/s
Z2 = 8.5m
P1 = atmospheric pressure?
I don't have V2
Im looking for z1.
Am I on the right track here, need some guidance please.
Okay I won't express in m3/s
The minimum vertical distance should be 3.94 metres.
Can someone show me how to solve please.
I will help you, but you need to show some work, according to the rules of this forum.
Please, see the importance of understanding and learning this over just solving a problem.
We will be here for you all the way, don't quit, keep trying.
What work have you done so far?
If none, we could start by discussing what you understand about NPSH from the point of view of energy of the fluid.
Next, set a general equation for the different parts that form the NPSH, considering the signs of each.
Then, convert all the given information to units of the International System of Units (SI), so we can use them in the equations.
Thanks I appreciate your help.
The NPSH is difference between suction head and liquid vapour head
Ps / yLiq + Vs^2 / 2g - Pv / yVap
Bernouilli:
P1/q + V1^2/2 + gh1 = P2/q + V2^2/2 + gh2
So like you say let's convert the flow rate to m/s
200hl / h-1
= 3.33 hl/min
= 333 L/min
1L/min = 10^-2 m^3/min
333L/min = 0.333 m^3/min
= 0.00555m^3/sec
Cross Sec Area
= 3.14(0.075/2)^2
= 0.0044
Velocity = Flow/Cross Sec Area
= 1.26 m/s
NPSH is:
Ps/Unit Weight + Vs^2 / 2g - Pv / Unit Weight
101.3/1065 +1.26^2 / 2(9.81) - 99 / 1065
= 0.0831 which is > 0
Darcys Friction Eq:
4(Friction Factor)(L/d)(density)(flow)^2
4 (0.002)(8.5/0.075)(1065)(1.26)^2
= 1532.94
Another NPSH Equation = Abs Pressure + vertical distance - Friction Loss + Velocity - Vapour Pressure
101300 Pa + H2 - 1532.94 +1.26 - 99,000 Pa
H2 - 765.8
Sorry, it was a long day for me.
Please, see comments below:
sci0x said:
Thanks I appreciate your help. You are welcome. :smile:
Net positive suction head is the energy level of the liquid at the point of entrance to the impeller of the pump.
Think of it as a safety margin that the system connected to any pump should have in order not to reach the vapor pressure of the liquid inside the impeller, which will create vapor formation and cavitation as the action of the impeller suddenly increases the pressure again.
Pump manufacturer's may give you a required NPSH, we are calculating the static head needed in the pipe system in order to achieve an available NPSH of value 4.
Note that Ps is in your above equation the absolute atmospheric pressure above the liquid (in meters) plus the height of the column of liquid above center of impeller or static head.
That static head should be referred to the lower level of the liquid, which is the worse condition.
Bernouilli:
Here we have a problem.
We have friction in the system, reason for which, total energy at surface of liquid = total energy at suction of impeller + energy wasted as friction (friction head).
200hl / h-1
= 3.33 hl/min
= 333 L/min
= 0.00555m^3/sec Correct!
Cross Sec Area
= 3.14(0.075/2)^2
= 0.0044
= 1.26 m/s Correct!
sci0x said:
NPSH is:
You are missing the static height of liquid here.
Refer to previous post.
Unify your units, everything should be in meters.
I followed Darcys Eq on this link:
Δpmajor_loss = λ (l / dh) (ρf v2 / 2)
(0.002) (8.5m)/(0.075m) (1065kgm-3)(1.26)^2 /2
=191.56
Can you give me the correct answer here if this is incorrect
The minimum vertical distance is shown in this formula: Book link
Hmax = (Pl - Pv)/qg - NPSH + (Vl^2-Vs^2)/2g - Friction
Hmax =
(101300Pa - 99,000Pa)/(1065kgm-3)(9.81m/s) - 4m + (1.26^2)/(2)(9.81m/s) - 191.45
= 0.2201 - 4m + 0.0809 - 191.56
= -3.699 - 191.56
I think I am nearly there with that Hmax formula if I could get the friction by Darcys Eq right. Can you finish this off for me so I can see how to get the 3.94 metres please.
What are the units of that number (191.56) and how did you reach that result?
I am sorry, but I can't follow.
Please, refer to post #10 above.
Calculate each head in meters.
Remember that the expected way to solve this problem was the application of the Bernoulli equation.
I used the linkk you gave me: 191.56 Pa
Δpmajor_loss = λ (l / dh) (ρf v2 / 2) (1)
where
Δpmajor_loss = major (friction) pressure loss in fluid flow (Pa (N/m2), psf (lb/ft2))
λ = Darcy-Weisbach friction coefficient - 0.002
l = length of duct or pipe (m, ft) - 8.5m
v = velocity of fluid (m/s, ft/s) 1.26 m/s
dh = hydraulic diameter (m, ft) 0.075 m
ρf = density of fluid (kg/m3, slugs/ft3) - 1065 kgm-3
I entered the results into the calc on the link and its giving 191 too.
I wish I had more time to spend on this but its been nearly a week since I posted this.
Calculating only friction head:
There is no schematic available, but in real life calculations, some equivalent length of tank-pipe transition (3.7 m), 90-degree elbow (1.2 m), gate isolation valve (2.6 m) and pipe reduction for pump entrance (1.5 m) should be added to the given length of pipe (8.5 m).
The value of the actual length plus the several equivalent lengths should be used in the Darcy equation.
##h_f={f_DV^2L}/{2gd}##
##h_f={(0.002)(1.257)^2(8.5+3.7+1.2+2.6+1.5)}/{(2)(9.81)(0.075)}##
##h_f=0.038~meters##
Please, see:
https://neutrium.net/fluid_flow/pressure-loss-in-pipe/
https://web.njit.edu/~barat/ChE396_Spring2011/EquivLengths.pdf
Calculating minimum height:
##Minimum~height=NPSH-(Atmospheric~pressure~absolute)+(Vapor~pressure~absolute)+(Friction~loss~head~in ~pipe)-(Velocity~head~at~pump~suction)##
##Minimum~height=NPSH-(P_{atm}/{\rho~g})+(P_v/{\rho~g})+({f_DV^2L}/{2gd})-(V^2/2g)##
:cool:
Thanks,
So my velocity is correct - 1.26m/s
My Darcys Friction is correct - 1532.98Pa
However i need to covert to m 1532.98/(1065)(9.81) = 0.1467m
I need to convert Pa to m like you suggested. I didn't know how, i do now,
Ha = 101300/(1065)(9.81) = 9.6596m
Hp = 99000/(1965)(9.81) = 9.67581 m
Ha + Hs = NPSH + Hp + HDarcys
9.69596m + Hs = 4m + 9.67581m + 0.1467m
Hs = 3.93m
Cheers
Likes Lnewqban
Related to Calculate pump height by using the Bernoulli Equation
1. How do I use the Bernoulli Equation to calculate pump height?
The Bernoulli Equation is a mathematical equation that relates the pressure, velocity, and height of a fluid. To use it to calculate pump height, you will need to know the fluid's density, the velocity of the fluid, and the pressure at two different points in the system. You can then rearrange the equation to solve for the height.
2. What is the significance of using the Bernoulli Equation to calculate pump height?
The Bernoulli Equation is significant because it allows us to understand the relationship between pressure, velocity, and height in a fluid system. By using this equation, we can accurately calculate the height that a pump needs to lift the fluid to overcome any losses in pressure or energy.
3. Can the Bernoulli Equation be used for all types of pumps?
Yes, the Bernoulli Equation can be used for all types of pumps as long as the fluid is incompressible and there are no significant changes in the fluid's density. However, the equation may need to be modified for certain types of pumps, such as positive displacement pumps, which have a different flow rate and pressure relationship.
4. What are the limitations of using the Bernoulli Equation to calculate pump height?
The Bernoulli Equation assumes that the fluid is incompressible and there are no significant changes in the fluid's density. This means that it may not accurately predict the pump height in systems with compressible fluids or where there are large changes in the fluid's density. Additionally, the equation does not account for losses due to friction or other factors, so it may not be entirely accurate in real-world scenarios.
5. Are there any alternatives to using the Bernoulli Equation to calculate pump height?
Yes, there are other equations and methods that can be used to calculate pump height, such as the energy equation or the hydraulic gradient equation. These may be more suitable for certain types of pumps or systems, so it is important to consider all options and choose the most appropriate method for your specific situation.
  • Mechanical Engineering
  • Mechanics
22K
