Calculate quality factor of a damped oscillation from a graph
In summary: This is a bit confusing. You cannot mean ##x(t) = A_0 e^{\frac{-xt}{2}}cos(\omega_d t - \alpha)## since that has an x both sides of the equation.If I change it to ##x(t) = A_0 e^{\frac{-\beta t}{2}}cos(\omega_d t - \alpha)## then the point at ##t=\frac{\pi}{120}## with ##\omega_d = 40 rad/s## would be ##(\frac{\pi}{120},0.5A_0 e^{\frac{-\beta 0.5}{2}})##In this case ##A_0e
Redwaves
134
I'm trying to find the quality factor of a damped system.
I know 3 points from the graph, ##(t,x): (\frac{\pi}{120},0.5), (\frac{\pi}{80},0), (\frac{\pi}{16},0)##
From this I found that ##T = \frac{\pi}{20}##
##\omega_d = \frac{2\pi}{T} = 40 rad##
Then, from the solution ##x(t) = A_0 e^{\frac{-xt}{2}}cos(\omega_d t - \alpha)##
##cos(\omega_d t - \alpha)## must be 0 when x = 0
##\omega_d t - \alpha = \frac{\pi}{2}##
##\alpha = 0##
I also know that ##Q = \frac{\omega_0}{\gamma}##
and
##\omega_0^2 = \omega_d^2 + \frac{\gamma^2}{4}##
I need some help to find ##\gamma##
Redwaves said:
Homework Statement:: Calculate quality factor of a damped oscillation from a graph
Relevant Equations:: ##x(t) = A_0 e^{\frac{-xt}{2}}cos(\omega_d t - \alpha)##
##\alpha = 0##
and
I make a mistake. It is
##x(t) = A_0 e^{\frac{-\gamma t}{2}}cos(\omega_d t - \alpha)##
Why t = 0.5 and not ##\frac{\pi}{120}##
In this case ##A_0e^{\frac{-\gamma t}{2}} = 1##
If ##\alpha = 0, A_0 = 1##?
##x(t) \neq 0.5A_0 e^{\frac{-\gamma t}{2}}##
Because, ##\gamma## or t must be 0.
However, the answer is ##\gamma = 18## and ##Q = \frac{41}{18}##
In this case ##\omega_0 = 41##
Using ##\omega_0^2 = \omega_d^2 + \frac{\gamma^2}{4}## where, ##\gamma = 18, \omega_d = 40##
##\omega_0 = 41## which is correct.
Ok.
Yes, I should have written:
If I change it to ##x(t) = A_0 e^{\frac{-\gamma t}{2}}cos(\omega_d t - \alpha)## then the point at ##t=\frac{\pi}{120}## with ##\omega_d = 40 rad/s## would be ##(\frac{\pi}{120},0.5A_0 e^{\frac{-\gamma\pi }{240}})##
Having t on the right must be wrong. Do you mean
##A_0e^{\frac{-\gamma \pi }{240}} = 1##
Redwaves said:
If ##\alpha = 0, A_0 = 1?##
Did you mean, If ##\gamma = 0, A_0 = 1##?
If so, yes.
##A_0=e^{\frac{\gamma\pi }{240}}##
##\alpha = 0##
I didn't get to this before. I think you mean
##cos(\omega_d t - \alpha)## must be 1 when t = 0, so ##\alpha = 0##
The information in post #1 is insufficient to determine ##\gamma##.
You need data points with two nonzero values of x. Do you know x at t=0?
If x(t) = 0 , ##A_0 = 0## or ##cos(\omega_d t - \alpha) = 0##
Thus, ##\omega_d t - \alpha = \frac{\pi}{2}##
##40 \cdot \frac{\pi}{80} - \alpha = \frac{\pi}{2}##
##\alpha = 0##
I had a another t on the graph ##\frac{\pi}{10}## I spent the entire day to figure the x position using a software and I found ##(\frac{\pi}{10}, e^{\frac{-33\pi}{40}})##
However, I still don't see how to get ##\gamma##
I tried ##\frac{-33\pi}{40} = \frac{-\gamma\pi}{20}##
##\gamma = 16.5##
##\alpha = 0##
##\gamma = 16.5##
You have an equation for ##x(\frac{\pi}{10})## and an equation for ##x(\frac{\pi}{120})##. You can eliminate ##A_0## between them and find ##\gamma##.
Please post your working as far as you get.
I get the expected answer.
Likes Redwaves
It works! it was obvious. I feel like I wasted my time and your time.
There are the 2 equations
##A_0e^{-\gamma \frac{\pi}{10}} = e^{\frac{-33\pi}{40}}##
##A_0e^{\frac{-\gamma \pi}{240}} = 1##
Once again, thanks!
One more thing.
If I don't have any point only the height of some maximums, I see that I can get Max1/Max2 and then
##\frac{e^{\frac{-\gamma t_1}{2}}}{e^{\frac{- \gamma t_2}{2}}} = \frac{Max_1}{Max_2}##
##\omega_d(t_2 - t_1) = 2\pi##
After some steps I have something like ##\omega_d = \pi \gamma##
I can do that because the maximums are controlled only by the damping ##e^{\frac{-\gamma t_1}{2}}##
It is correct?
I didn't understand the last step. What happened to the maxima?
If the attenuation over consecutive maxima is ##\beta=Max_2/Max_1## then ##\beta=e^{-\frac \gamma 2 T}##, ##\gamma=-\frac 2T\ln(\beta)=-\frac {\omega_d}{\pi}\ln(\beta)##.
FAQ: Calculate quality factor of a damped oscillation from a graph
How do I calculate the quality factor (Q) from a graph of a damped oscillation?
To calculate the Q factor from a graph of a damped oscillation, you need to find the peak amplitude (A) and the half-power points (A/√2) on the graph. Then, use the formula Q = πA/2(A/√2). This will give you the Q factor of the oscillation.
What is the significance of the quality factor in a damped oscillation?
The quality factor (Q) in a damped oscillation represents the sharpness or selectivity of the oscillation. It is a measure of how well the oscillation maintains its energy over time. A higher Q factor indicates a more efficient and less damped oscillation.
Can the Q factor be greater than 1?
Yes, the Q factor can be greater than 1. In fact, a Q factor of 1 is considered critically damped, while a Q factor greater than 1 indicates an underdamped oscillation.
How does the damping affect the quality factor in an oscillation?
The damping in an oscillation affects the quality factor by reducing its value. This is because damping dissipates energy from the oscillation, causing it to lose amplitude over time. Therefore, a higher damping coefficient will result in a lower Q factor.
What are some real-life applications of the quality factor in oscillations?
The quality factor is an important concept in various fields, including electrical engineering, physics, and mechanical engineering. It is used in designing and analyzing circuits, tuning musical instruments, and understanding the behavior of mechanical systems. In addition, the Q factor is also used in the study of resonance phenomena, such as in radio frequency circuits and seismology.
