Calculate resultant force of a linear mechanism
In summary, the conversation discusses designing a linear to linear transform mechanism and calculating the force required to push or slide a roller down. The conversation also includes a question about drawing the resultant force diagram and whether the friction force can be ignored if the roller is mounted with a bearing. The summary concludes with a mention of the potential friction force between the slider and sliding surface being a bigger problem.
Travis T
TL;DR Summary
Would like to calculate force required for a wedge cam design
Hi all,
I'm currently designing a linear to linear transform mechanism (wedge cam design).
Would like to check how much force required to push/ slide the roller down.
To ease calculation, i have include some assumption:
F2 = 1kg @ maximum compressed
angle = 20degree
F1 required = ?
and how to draw the resultant force diagram for this example?
Thanks.
Is this homework?
The resultant force diagram is centered on the point where the roller contacts the wedge. The force vector is perpendicular to the surface at the point of contact. You have the vertical component of that force vector. Get that part of the diagram right before doing the calculations.
Thanks for reply,
It is not a homework.
It is for machine designing.
The figure is just drafted to show basic mechanism motion.
The normal force is certainly normal to the surface, but there will also be some amount of friction tangent to the surface.
Likes Travis T
Since the two forces are orthogonal; F1 = F2 * Tan( 20° )
Likes Lnewqban and Travis T
If the roller is mounted with bearing, will friction force insignificant and can be ignored?
If the bearing is a simple cylindrical pin then friction will depend on lubrication and it may be a problem. If the bearing is a low friction rolling bearing then friction will probably not be a big problem.
The friction force between slider and sliding surface may be a bigger problem regarding additional F1 needed to overcome friction.
FAQ: Calculate resultant force of a linear mechanism
1. What is a resultant force?
A resultant force is the overall force acting on an object, taking into account all of the individual forces acting on it.
2. How do you calculate the resultant force of a linear mechanism?
To calculate the resultant force of a linear mechanism, you must first identify all of the individual forces acting on the mechanism. Then, you can use vector addition to find the resultant force by adding all of the forces together.
3. What is vector addition?
Vector addition is a mathematical process used to combine multiple vectors, which have both magnitude and direction, into a single resulting vector.
4. How do you represent forces in a linear mechanism?
Forces in a linear mechanism can be represented by arrows, with the length of the arrow representing the magnitude of the force and the direction of the arrow representing the direction of the force.
5. What factors can affect the resultant force of a linear mechanism?
The resultant force of a linear mechanism can be affected by the magnitude and direction of individual forces, as well as the angle at which they act on the mechanism. Other factors such as friction and weight distribution can also affect the resultant force.
