Calculate Speed of Relativistic Rocket by Observation
In summary, the passenger on the rocket can calculate the speed of the rocket using the equation v = L/TimeA, but not using the equation v = L/TimeB.
Azaravicius
Hi, here are image of situation. We have observer in point A. He have clock and know distance L between points B and C. He is observing rocket travel from point B to point C at speed near light speed. Can he calculate the speed of rocket using v = L / TimeA?
In rocket at point B here are passenger with clock. He knows distance L between points B and C. After arrival in point C he calculates time it took to travel from point B to point C for him. Can he calculate the speed of rocket using v = L / TimeB?
From relativity we know that time in rocket will be slower nor for point A. And if rocket speed are 100 km/h?
Yes.
No. In his rest frame he knows his speed - zero. He can calculate the velocity of the dots you labelled B and C (perhaps they are space stations or marker bouys or something) using measurements in his frame. He will come up with the same answer as A, although with the opposite sign because the dots are moving left to right while he is moving right to left.
Relativistic calculations work at all speeds. It's just that at 100km/h the difference from the Newtonian form is so small that it's not worth the more complex maths.
Yes, that's how he can determine that "rocket travel from point B to point C at speed near light speed". It's very important to note here that both L and TimeA are measured in the same frame of reference, that of A.
Here you are making a common mistake, you are mixing up measurements from different frames. In the reference frame of the passenger the distance between B and C is not L. It would be ok to calculate the speed of B-C (not of the rocket, which is at rest in this frame) that way by using a correct distance in that frame. It would come up to the same v as calculated by A, just in the opposite direction.
So, distance isn't absolute but it depends at the speed of observer who makes measurements?
Yes. Usually the phenomenon is called "length contraction". There's a fairly subtle interplay between that, time dilation, and the relativity of simultaneity. Your best bet is to study the Lorentz transforms, and I strongly recommend looking up Minkowski diagrams too.
Thanks.
Related to Calculate Speed of Relativistic Rocket by Observation
1. How is the speed of a relativistic rocket calculated?
The speed of a relativistic rocket can be calculated using the equation v = c * tanh(at/c), where v is the velocity of the rocket, c is the speed of light, a is the acceleration of the rocket, and t is the time experienced by the observers on the rocket.
2. What is the significance of using a relativistic calculation for the speed of a rocket?
Relativistic calculations take into account the effects of special relativity, which becomes increasingly important as an object approaches the speed of light. This is especially relevant for objects traveling at high speeds, such as a rocket, and provides a more accurate measurement of its velocity.
3. How does the observation of the rocket affect the calculation of its speed?
The observation of the rocket plays a crucial role in calculating its speed as it provides a frame of reference for the measurement. The time experienced by observers on the rocket is a key component in the relativistic speed equation.
4. Can the speed of a relativistic rocket be calculated without any observations?
No, the speed of a relativistic rocket cannot be accurately calculated without any observations. The time experienced by observers on the rocket is a crucial factor in the calculation, and without this information, the calculation would not be possible.
5. How does the acceleration of the rocket affect its speed?
The acceleration of the rocket directly affects its speed as it is a component in the relativistic speed equation. The higher the acceleration, the faster the rocket will travel, but this also means that the effects of special relativity become more significant and must be accounted for in the calculation.
