Calculate surface integral on sphere
Addez123
199
Do surface integral using spherical coordinate system over
Surface is a sphere at origin with radius R.
Not gauss
I'm supposed to do the surface integral on A by using spherical coordinates.
Now I'm trying to do
Which obviously doesn't work because I'm trying to integrate over a vector.
What I suspect I'm supposed to do is
However I'm not sure what e_r is..
If expressed in spherical coordinates it's (1, 0, 0)
But I cant just do
and get any resonable answer.
So I'm stuck because I can't extract A_r from A.
If , then .
pasmith said:
If , then .
Is thick r a vector with another r as variable? I always find that extremly confusing..
As I understand it
But the answer should just be 4 pi.
Even if I had I would end up with an r in the solution so I'm not sure what I'm doing wrong.
Does clarify things?
Likes Addez123
Addez123 said:
Is thick r a vector with another r as variable? I always find that extremally confusing..
The variable , when written in bold typeface (you referred to as "thick"), indicates that is a vector quantity. The variable in standard typeface is used to refer to the magnitude of the vector .
Alternatively, you may have seen an arrow or harpoon above a variable to indicate a vector quantity. For instance or .
Also notice that , as it is defined in the OP, is a vector quantity. Write as .
As I understand it
Another issue which may be leading to your confusion has to do with coordinate systems versus vector components. For instance, when you write
you are using spherical coordinates, but the components are rectilinear, i.e. they are along directions. On the other hand, when you wrote , the components are spherical as well as the coordinates ,
No need to go to spherical components.
Addez123 said:
Homework Statement:: Do surface integral using spherical coordinate system over
Relevant Equations:: Not gauss
Now, let's look at the OP.
You have an error in that expression for A.
so what you should have for A is:
Don't forget, the integral is over the surface of the sphere of radius , centered at the origin, so .
You now have all the parts, so ...
Take the scalar product and integrate.
Likes Addez123
Its been a while for me, but couldn't we just take the dot product of A (most textbooks have A written as F for vector function) and a unit vector normal to the sphere times Ds? Since the sphere is centered at the origin, we know that a normal unit vector is given by (x,y,z) divided by its magnitude (sorry for no LaTek on a trip and do not have access to a computer) is normal to it.
Now, what is Ds (magnitude of the vector Ds) for a sphere?If you cannot recall, find the surface element on another sheet of paper. Integrate
We can also just find the vector Ds and find the dot product of A and this vector.
Do not forget to change to polar
I glanced at the problem, but did not attempt it on my own. This is the general idea for these types of problems.
Ah yes, a should be divided by r^3 not r^3/2.
I calculated which is in normal components.
Then and I solved it.
Thanks!
