Calculate the airplane's acceleration
  • Thread starter ConfusedMonkey
  • Tags
    Acceleration
In summary, the airplane's downward acceleration must be greater than 9.8 m/s^2 for the pretzels to appear to rise with an acceleration of 2 m/s^2.
ConfusedMonkey
42
Your airplane is caught in a brief, violent downdraft. To your amazement, pretzels rise vertically off your seatback tray, and you estimate their upward acceleration relative to the plane at ## 2 \hspace{0.1cm} m/s^2##. What's the plane's downward acceleration?
I don't think I need help with the math, but I do need help understanding what's going on here. I figure that we need to focus on the plane and not the pretzels because if we choose the reference frame to be inside of the airplane, then it isn't an inertial reference frame and so Newton's laws are no longer valid, correct?
So I figure that if the plane were to accelerate downward slowly, the pretzels would stay put, but if the plane were to accelerate downward very quickly, then the pretzels would jump up off of the tray. Since the pretzel's acceleration is ##2 \hspace{0.1cm} m/s^2##, then I need to find the maximum downward acceleration the plane can undergo without the pretzels jumping up, and I need to subtract ##2## from that (subtract instead of add because downward acceleration is negative). I just can't figure out how to get that number.
In free fall (acceleration of 1g down), what would happen?
PS. A lot of coordinate systems make acceleration down positive, so check what it is in the coordinate system you have.
Likes ConfusedMonkey
You probably saw examples about elevators and the "change in weight" they can cause, you can also visualize what happens by just having a pen on top of your hand and then quickly moving your hand down, the pen won't catch up with your hand and it will "float" upwards if your frame of reference is actually your hand.
If it were in free fall, the pretzels would still be on the tray because only gravity would be acting on the plane and on the pretzels. But there is nothing in the question to indicate free fall. From what I see, the forces on the plane are gravity, the force of the air which pushes the plane up, and the downward wind draft which is causing turbulence.
EDIT: If it were in free fall, the pretzels would remain on the tray since they too would also be in free fall, but if the plane all of a sudden started accelerating downward, then the pretzels would keep their initial acceleration of -9.8 m/s^2. This must mean that for the pretzels to appear as if they are rising with an acceleration of 2 m/s^2, then the plane must be accelerating downward at 9.8 + 2 = 11.8 m/s^2. But still, this is assuming it is in free fall, as I mentioned above, there are other forces to take into consideration.
EDIT 2: If the plane is accelerating downward, obviously the net force points downward. As long as the acceleration that the plane moves downward at is 9.8 m/s^2 or less, then the pretzels will fall at the same rate and thus NOT come off of the tray. However, as soon as the planes downward acceleration passes this point, then the pretzels MUST start to "rise". The fact that the pretzels appear to accelerate upward at 2 m/s^2 means thus means that the plane must be accelerating downward at 11.8 m/s^2. I think I've got it!
Likes FactChecker
Yes, that should be the correct thought process
Related to Calculate the airplane's acceleration
What is acceleration and how is it calculated?
Acceleration is the rate at which the velocity of an object changes over time. It is calculated by dividing the change in velocity by the change in time.
How do you calculate the airplane's acceleration?
To calculate the airplane's acceleration, you would need to know its initial velocity and final velocity, as well as the time it takes to change from the initial velocity to the final velocity. Then you would use the formula a = (vf - vi) / t, where a is the acceleration, vf is the final velocity, vi is the initial velocity, and t is the time.
What units are used for measuring acceleration?
Acceleration is measured in meters per second squared (m/s²) in the metric system. In the imperial system, it is often measured in feet per second squared (ft/s²).
How does air resistance affect the airplane's acceleration?
Air resistance, also known as drag, can slow down the airplane and decrease its acceleration. The amount of air resistance depends on factors such as the shape and size of the airplane, its speed, and the properties of the air.
Can the airplane's acceleration be negative?
Yes, the airplane's acceleration can be negative if it is slowing down or decelerating. This means that the final velocity is less than the initial velocity, resulting in a negative change in velocity and, therefore, a negative acceleration.
