Calculate the arc length of the vector function
In summary, the arc length of <2t,t^2,lnt> from 1=<t=<e can be calculated using the formula ∫√{(x')^2 + (y')^2 + (z')^2}dt. After factoring the expression in the integrand, it becomes ∫√{(2t + 1/t)^2}dt. To integrate this, you can use the substitution method or the power rule for indefinite integrals.
jaydnul
558
Calculate the arc length of [itex]<2t,t^2,lnt>[/itex] from [itex]1=<t=<e[/itex]
Arc length=[itex]∫√{(x')^2 + (y')^2 + (z')^2}[/itex]
So I have gotten to this point:
[itex]∫√{4 + 4t^2 + \frac{1}{t^2}}[/itex]
Am I on the right track, and if so, how do I integrate that?
Missing dt in the integrand.
Also, if you use \sqrt instead of √, it will look better.
$$\int \sqrt{x'^2 + y'^2 + z'^2}dt $$
Write the quantity in the radical as 4t2 + 4 + 1/t2, and then factor it.
Thanks. Good advice so far. I think I might just be an idiot by how do you factor that? Haven't had to do that for a while.
Nevermind, got it. multiply t^2
Thanks for the help!
You can't do that, but you can multiply by t2 over itself. OTOH, the expression can be factored directly, to (2t + 1/t)2.
Related to Calculate the arc length of the vector function
What is the definition of arc length?
Arc length is the distance along a curve or arc, measured as the length of the curve from one point to another.
What is a vector function?
A vector function is a mathematical function that takes in one or more inputs and produces a vector output.
How do you calculate the arc length of a vector function?
The arc length of a vector function can be calculated using the formula:
S = ∫√(1 + f'(x)^2)dx
where f'(x) is the derivative of the vector function and the integral is taken over the given interval.
Can the arc length of a vector function be negative?
No, the arc length of a vector function cannot be negative as it represents a physical distance and must be positive.
What is the significance of calculating the arc length of a vector function?
Calculating the arc length of a vector function is important in many fields of science and engineering, as it helps in understanding the shape and properties of curves, calculating work done by a force, and finding the shortest distance between two points in space.
