Calculate the best angle for maximum light dispersion through a medium
The discussion centers on calculating the optimal angle for maximum light dispersion through a medium, initially considering the critical angle for total internal reflection. The critical angle equation is derived, leading to the differentiation of the angle with respect to wavelength. The participant proposes setting the derivative to zero to find the wavelength that maximizes the angle. Another contributor suggests that maximizing wavelength concerning the angle requires a different approach, specifically calculating the derivative of wavelength with respect to the angle. The conversation highlights the complexity of the relationship between angle and wavelength in light dispersion.
Jan Berkhout
If you have light moving from ##n_1## to ##n_2## you can get dispersion if ##n_1## is a function of wavelength.
What angle of incidence ##(θ_1)## will maximise the dispersion for the situation below where the light goes from a medium with ##n_1(λ)## to vacuum, ##(n_2 = 1)##?
$$\frac{d \sin ^{-1}(\text{ax})}{\text{dx}}=\frac{a}{\sqrt{1-(ax)^2}}$$ $$\frac {dy}{dx}=\frac{dy}{dz} \frac{dz}{dx}$$
I first thought that the angle would have to be maximum when it is closest to the critical angle for total internal reflection. From my lectures the equation for the critical angle is ##\theta _1>\ sin ^{-1} \left( \frac {n_2} {n_1} \right),## so as ##n_2 = 1##, we have ##\theta _1=\sin ^{-1}\left(\frac{1}{n_1(\lambda)}\right)##. I didn't really know what to do after that but from the equations given in the hint (relevant equations), I thought I'd have to differentiate with respect to ##\lambda##. This gives $$\frac {d θ_1} {d \lambda} = -\frac{\frac{d}{{d \lambda}} n_1(\lambda)}{n_1(\lambda) \sqrt{n_1(\lambda)^2-1}}.$$ So I have the change in the critical angle with respect to the change in wavelength, so my hunch is I have to set the derivative to 0 and solve for \lambda to find the wavelength for the maximum angle then I can calculate the angle? Is this right?
I worked hard and actually believe I have solved it! So this thread can be closed :)
Don't you want to maximise ##\lambda## wrt ##\theta_1##? For that you need $$\frac {d \lambda} {d θ_1}$$.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
