bravopipo
- 6
Hello;
I have as shown in the picture, a rope (in green), this rope is located between a support A and a support B. The Support A doesn't move and attached to the ground. The support B apply a force F1 against the rope, this force is made by a helical compression spring.
Because there is a friction between the rope and the two supports A and B, and because the spring push B toward A so we conclude that much the force F1 increase much it is harder to overcome the friction and move the rope.
The question is: How can I calculate the force F1 required to achieve a minimum overcome force T1 of 200 Newtons ? what I mean by this, is what characteristics the spring should have in order to generate a pushing force F1 that require at minimum 200 Newtons applied to the rope in order to move it ?
If the problem is difficult, may someone please give me a link to a similar problem to seek a solution.
1. Coefficient of friction Rope/Support : u
2. Rope diameter : d
3. Weight of support B : Neglected
1. Simple spring equation.
2. Friction force between rope and two supports.
Neglect the weight of support B, and suppose the contact area between rope and the two supports is A, otherwise I don't know.
Thank You.
