Calculate the concentration of hydrogen peroxide
In summary, an aliquot of 10mL from a reaction containing 0.0176M permanganate solution was titrated with 0.01 M H2O2. The resulting endpoint was found to require 32.8mL of titration solution. If the concentration of hydrogen peroxide in the aliquot is 0.0568 M, then the ln([H2O2]) value is approximately -2.868.
Me!!
can anone help me with these questions?
a) How many moles of hydrogen peroxide react with each mole of permanganate in the titrationmoles of MnO4- per mole of H2O2
b) Calculate the concentration of hydrogen peroxide in the 10 mL aliquot, taken from the reaction if the titration with 0.0176 M permanganate solution requires 32.8 mL to reach the end-point
c) If the concentration of hydrogen peroxide in the 10 mL aliquot is 0.0568, calculate ln([H2O2])
your help will be greatly appreciated!
Chemistry news on Phys.org
Hello,
I will try to solve the problems.
My answer: As you know, peroxide reacts with permanganate to yield elemental oxygene and manganese(IV) oxide:
2Mn(7+) + 6e(-) --> 2Mn(4+)
3O2(2-) --> 3O2 + 6e(-)
2KMnO4 + 3H2O2 --> 2MnO2 + 3O2 + 2KOH + 2H2O
Thus, 2 moles of permanganate is required to oxidize 3 moles of peroxide.
My answer: I like to express the milimoles by directly multiplying the molarity and titer; so we obtain 0.0176*32.8=0,57728 milimoles of permanganate. We will multiply this value with 1.5 (as seen from the mole ratio between permanganate and peroxide in the reaction above) to learn the amount of reacted peroxide: 0.86592 milimoles of peroxide in 10 mL solution. This gives a 0,086592 M solution.
My answer: I assume that [H2O2] is expressed as molar concentration, so we may directly calculate the ln value from this: in this way, we obtain approximately -2.868.
I may be wrong, but I have not found any errors.
Regards
chem_tr
a) In a titration, the mole ratio between the reactants can be used to calculate the concentration of one substance from the known concentration of the other. In this case, the mole ratio between H2O2 and MnO4- is 1:5. This means that for every 1 mole of H2O2, 5 moles of MnO4- are needed for complete reaction.
b) To calculate the concentration of H2O2 in the 10 mL aliquot, we first need to determine the number of moles of MnO4- used in the titration. This can be calculated by multiplying the volume of MnO4- used (32.8 mL) by its concentration (0.0176 M):
n(MnO4-) = (0.0328 L)(0.0176 mol/L) = 0.0005776 mol
Since the mole ratio between H2O2 and MnO4- is 1:5, the number of moles of H2O2 in the aliquot is 1/5 of the moles of MnO4- used:
n(H2O2) = 0.0005776 mol/5 = 0.00011552 mol
Now, we can use the volume of the aliquot (10 mL) to calculate the concentration of H2O2:
[H2O2] = n(H2O2)/V(aliquot) = 0.00011552 mol/0.010 L = 0.011552 M
c) To calculate ln([H2O2]), we first need to convert the concentration of H2O2 from M to mol/L:
[H2O2] = 0.0568 mol/L
Now, we can use the natural log function to calculate ln([H2O2]):
ln([H2O2]) = ln(0.0568 mol/L) = -2.868
Related to Calculate the concentration of hydrogen peroxide
1. How do I calculate the concentration of hydrogen peroxide?
To calculate the concentration of hydrogen peroxide, you will need to know the volume and molarity of the solution. Then, use the formula M1V1 = M2V2, where M1 is the initial molarity, V1 is the initial volume, M2 is the final molarity, and V2 is the final volume.
2. What are the units for concentration of hydrogen peroxide?
The units for concentration of hydrogen peroxide are typically expressed in moles per liter (M) or millimoles per liter (mM).
3. Can I use any concentration units to calculate the concentration of hydrogen peroxide?
Yes, you can use any concentration units as long as they are consistent on both sides of the equation. For example, if you use moles per liter for one side, you must use moles per liter for the other side.
4. Can I calculate the concentration of hydrogen peroxide without knowing the volume?
No, the volume of the solution is a crucial factor in calculating the concentration of hydrogen peroxide. Without the volume, you will not be able to use the formula M1V1 = M2V2 to find the concentration.
5. What is the purpose of calculating the concentration of hydrogen peroxide?
Calculating the concentration of hydrogen peroxide is essential in many scientific experiments and processes. It allows scientists to accurately measure and control the amount of hydrogen peroxide present in a solution, which can affect the outcome of their experiments or reactions.
