Calculate the 'Feel' of a Drumhead?
In summary, the conversation discusses the possibility of calculating the 'feel' of a drumhead using mathematical models and equations. The speaker mentions their own personal music project and how they used Hooke's Law to relate it to another project. They are interested in finding a generalized value for the 'give' of a drumhead and have constructed an equation to predict the tension of a drumhead. They also mention the logarithmic scale of sound and their plans to test their theories physically.
Chrono G. Xay
92
As another of my personal music projects, I have wondered if it would not be possible to calculate the 'feel' of a drumhead (i.e. the amount of 'give' expressed as transverse displacement 'z' that an equally pre-tensioned circular membrane of radius 'r' experiences when struck on its plane at a point a radial distance 'd' from its center, where 0 < d < r ) .
I tried to imagine just how it would deform when struck, and the most simple mathematical model that I can come up with is when it is struck in the center, represented by the graph of 'sqrt( x )' revolved about the y-axis. I don't have my notes with me right now (I'm on my honeymoon, but wanted to finally put this question up here), but in a related--complete--project I've been working on, which involves calculating the 'relative' angular displacement and torque needed to execute any rhythm with any sticking at any tempo, I was able to tie it into this one using Hooke's Law (or at least the Law of Conservation of Energy, given the implement's moment of inertia, center of mass, terminal angular velocity, and, technique-wise, the use of only the fingers, a la 'Gladstone'- the use of the wrist, or rather any set of joints besides the fingers, would obviously require additional maths).
Anyway, with this project I'm more interested in obtaining a more generalized value for the 'give', where the angular momentum is a set value like 1 rad•kg•m/s, the idea being that each time a drumhead is virtually 'struck' in this simulation it is exactly the same.
I know I was able to construct an equation that would allow me to find the 'feel' of a drumhead at any point between the center of its plane and its edge, the goal being a graph with respect to 'd' that would explain the general change in 'feel' much more easily for the layman musician, but for the time being went with the most mathematically simple model, where d=0
(For what it's worth, I do understand, going in, that the dynamical level of a sound, whose scientific magnitude is measured in deciBells, is logarithmic in scale, base 10.)
I'll be back home in another few days, where I can post some pictures of my work so far.
I started with the equation for Elastic Modulus,
E = /frac{σ,ε} = /frac{F / A_i,ΔL / L_i
=> F = /frac{ΔL,L_i}*E*A_i
and from there further defined the terms as they seemed to be:
ΔL = L_f - L_i => /frac{ΔL,L_i} = /frac{L_f - L_i,L_i} = /frac{L_f,L_i} - 1
L_f = L_{1f} + L_{2f}
L_i = L_{1i} + L_{2i}
/frac{L_f,L_i} - 1 = /frac{L_{1f} + L_{2f},L_{1i} + L_{2i}} - 1
F = T
'T' - Tension on membrane
However, I know I need to tie this in to
F_s = -k*x
and in my case 'x' would be more like 'z'.
I arrived at an equation for theoretically predicting the tension a drumhead by manipulating the geometries I input when constructing the equation for tension on a string- a thin, large cylinder instead of a small, long cylinder. I have yet to construct a physical apparatus for testing it.
Related to Calculate the 'Feel' of a Drumhead?
1. What is the purpose of calculating the 'feel' of a drumhead?
The purpose of calculating the 'feel' of a drumhead is to understand the physical properties of the drumhead, such as tension, material, and thickness, which can affect the sound and responsiveness of the drum.
2. How is the 'feel' of a drumhead calculated?
The 'feel' of a drumhead is calculated by measuring the tension of the drumhead using a tuning key or a drum dial, and also by measuring the thickness and material of the drumhead using a micrometer. These measurements are then used to determine the drumhead's elasticity, which is a key factor in its 'feel'.
3. What factors can affect the 'feel' of a drumhead?
The tension, thickness, and material of the drumhead are the main factors that can affect its 'feel'. Other factors such as the type of drum, drum size, and playing style can also have an impact on the drumhead's 'feel'.
4. How does the 'feel' of a drumhead affect its sound?
The 'feel' of a drumhead can greatly affect its sound. A tighter drumhead with higher tension will produce a higher-pitched and more responsive sound, while a looser drumhead with lower tension will produce a lower-pitched and less responsive sound. The type of material and thickness of the drumhead can also affect the tone and sustain of the sound.
5. Can the 'feel' of a drumhead be adjusted?
Yes, the 'feel' of a drumhead can be adjusted by changing the tension, material, or thickness of the drumhead. This can be done by using a tuning key to tighten or loosen the drumhead, or by changing to a different type of drumhead with a different material or thickness. Experimenting with different adjustments can help achieve the desired 'feel' for the drumhead.
  • Classical Physics
  • Astronomy and Astrophysics
  • General Discussion
