Calculate the final speed of the pin
In summary, according to the law of conservation of momentum, the final momentum of the pin must equal the initial momentum of the bowling ball, which is 60 m_p up. The pin flies off at an angle of 80* from the original direction of the ball, meaning the ball must be traveling at some angle to the left in order to cancel out the pin's momentum in the +x direction. Both the ball and the pin have some final momentum in the +y direction, which must add up to the initial upward momentum. The actual calculations can be done using the given information and equations.
JoeCool9
Assume that a bowling ball, initially traveling at 12.0m/s, has 5 times the mass of a pin and that the pin goes off at 80* from the original direction of the ball. A) Calculate the final speed of the pin, B) the final speed of the ball, C) and the angle through which the ball was deflected. Assume the collision is elastic.
This relies on the law of conservation of momentum, initial momentum = final momentum.
In the initial conditions, the only thing that is moving is the bowling ball, moving "up" the lane at 12 m/s. We know that the bowling ball is 5 times the mass of the pin (m_p). So we can use this to calculate the initial momentum as,
(12 m/s)*(5 m_p) = 60 m_p up.
So we know that the final momentum must equal this.
Say you put a coridinate grid out on the bowling lane, with up (the original direction of travel by the bowling ball) in the +y, and right as +x.
The final conditions saw the pin flies off at 80* from the original bowling ball direction (we will say right, in the +x direction), meaning the pin has some momentum in the +x direction. This was not the case in the original conditions, all the momentum was stright up, so in order to cancel this out, the bowling ball must be traveling at some angle to the left in the -x direction.
Also we know the pin [and bolwing ball] have some final momentum in the stright up (+y) direction. We know that the ball's and the pin's momentums must add together to give the final upward momentum, which is equal to the initial upward momentum.
I will leave all the math up to you.
A) To calculate the final speed of the pin, we can use the conservation of momentum and energy equations. Since the collision is assumed to be elastic, we can equate the initial and final momentum and kinetic energy of the system. Let m1 be the mass of the bowling ball and m2 be the mass of the pin.
Initial momentum of the system = m1v1 + m2v2 = (5m)(12.0m/s) + m(0) = 60m/s
Final momentum of the system = m1v1' + m2v2' = (5m)v1' + mv2'
Since the pin goes off at an angle of 80*, we can break down the final velocities into their x and y components:
v1' = v1cos(80*) = (12.0m/s)(0.1736) = 2.08m/s
v2' = v2sin(80*) = (v2)(0.9848)
Now, equating the initial and final momentum, we get:
60m/s = (5m)(2.08m/s) + (mv2)(0.9848)
Solving for v2, we get v2 = 57.7m/s
B) To calculate the final speed of the ball, we can use the same equations as above:
v2' = v2sin(80*) = (v2)(0.9848) = (57.7m/s)(0.9848) = 56.8m/s
C) To calculate the angle through which the ball was deflected, we can use trigonometric properties:
tan(angle) = v2y/v2x
tan(angle) = (v2sin(80*))/(v2cos(80*))
tan(angle) = (57.7m/s)(0.9848)/(57.7m/s)(0.1736)
tan(angle) = 5.663
angle = tan^-1(5.663) = 80*
Therefore, the angle through which the ball was deflected is also 80*.
In conclusion, the final speed of the pin is 57.7m/s, the final speed of the ball is
Related to Calculate the final speed of the pin
1. What is the formula for calculating the final speed of a pin?
The formula for calculating the final speed of a pin is v = u + at, where v is the final speed, u is the initial speed, a is the acceleration, and t is the time.
2. How do you determine the initial speed of a pin?
The initial speed of a pin can be determined by measuring the distance the pin has traveled and the time it took to travel that distance. Then, using the formula v = d/t, where v is the initial speed, d is the distance, and t is the time, the initial speed can be calculated.
3. What is the acceleration of a pin?
The acceleration of a pin is the rate at which its speed changes over time. It can be calculated by dividing the change in speed by the time it takes for that change to occur, or by using the formula a = (v-u)/t, where a is the acceleration, v is the final speed, u is the initial speed, and t is the time.
4. Can the final speed of a pin be negative?
Yes, the final speed of a pin can be negative if it is slowing down. This indicates that the pin is moving in the opposite direction of its initial motion. It is important to pay attention to the direction of the motion when calculating final speed.
5. How can the final speed of a pin be affected?
The final speed of a pin can be affected by factors such as initial speed, acceleration, and time. Additionally, external forces such as friction or air resistance can also impact the final speed of a pin. Changes in these factors can result in changes to the final speed of a pin.
  • Classical Physics
