Calculate the Flame temperature
  • Thread starter GeorgeP1
  • Tags
    Temperature
In summary, the problem involves determining the maximum flame temperature when a fuel gas consisting of 75% butane, 10% propane, and 15% butene is fed into a combustion chamber with 10% excess air at 25°C. The resulting flue gases are used to generate 5 bar steam from water at 90°C. The solution involves calculating the heat input and output of the process using the heat capacities of the products of combustion, including H2O, CO2, O2, and N2, and assuming a flame temperature of 2000°C. The final result is a maximum flame temperature of 1987°C.
GeorgeP1
A fuel gas consists of 75% butane (C4H10), 10% propane (C3H8) and 15% butene (C4H8) by volume.
It is to be fed to the combustion chamber in 10% excess air at 25°C, where it is completely burnt to carbon dioxide and water. The flue gases produced are to be used to generate 5 bar steam from water at 90°C.
Determine the maximum flame temperature ?.
[/B]
heat input to process = heat out of process
Heat out of process = ∑ (mass × mean specific heat capacity × TF ) for each product of combustion
[/B]
2581 Kj
1987°C
This answer is incorrect.
Any help is much appreciated.
C'mon --- you know the "drill" --- sum the heat capacities, do the division, ...
butane = -2660 kj/mol
propane = -2046 kj/mol
butene = -2540 kj/mol
heat released by 1 mole of fuel
= (0.75x2660)+(0.1x2046)+(0.15x2540)
=2581 kj (heat in)
is this correct so far?
What are the products, and what are their heat capacities?
Flue gas =
H2O = 4.75 moles
CO2 = 3.9 moles
O2 = 0.63 moles
N2 = 26.06 moles
Total = 35.34 moles
Heat content = enthalpy x no. of molesFor N2, 66.10 x 26.06 = 1722.6 kJ
CO2, 108.32 x 3.9 = 422.5 kJ
O2, 69.65 x 0.63 = 43.9 kJ
H2O, 86.24 x 4.75 = 409.6 kJ
Total = 2598.6 kJ
how does this look?
GeorgeP1 said:
how does this look?
George - looks good to me, did anyone agree?
Related to Calculate the Flame temperature
1. What is the flame temperature?
The flame temperature is the maximum temperature that a flame can reach under specific conditions. It is the result of the combustion process, where fuel reacts with oxygen to produce heat.
2. How is the flame temperature calculated?
The flame temperature can be calculated using the adiabatic flame temperature equation, which takes into account the properties of the fuel and oxidizer, such as their chemical composition and the amount of heat released during combustion.
3. What factors affect the flame temperature?
The flame temperature can be affected by various factors, such as the type of fuel and oxidizer, their ratio, the temperature and pressure of the surroundings, and the presence of any impurities or additives.
4. Why is it important to calculate the flame temperature?
Calculating the flame temperature is important in various fields, such as combustion engineering, chemical engineering, and fire safety. It can help determine the efficiency of a combustion process, the potential for chemical reactions, and the potential hazards of a fire.
5. Are there any limitations to calculating the flame temperature?
Yes, there are some limitations to calculating the flame temperature. It is an idealized value that assumes perfect combustion and does not take into account factors such as heat loss, flame turbulence, and chemical reactions. Therefore, the calculated flame temperature may differ from the actual temperature in a real-world scenario.
