Calculate the flow of steam to heat wort (in the brewing process)
In summary: Change in Enthalpy = 2739 - 605 = 2135 kj kg-1Can i say initial enthalpy = (2739)(0.66) = 2738.34Final enthalpy = (605)(0.66) = 399.3Difference = 2339.04 kJ
sci0x
83
A brewery requires wort to undergo 5% by mass evaporation in one hour. The wort is boiled at atmospheric. Using the data below, calculate flow of steam required.
Saturated steam pressure = 3 bar gauge
Condensate pressure in wort boiler = 3 bar gauge
Enthalpy of steam, at 3 bar gauge = 2739 kg kj-1
Enthalpy of water at 3 bar g = 605 kj kg-1
Initial wort volume at 100 deg c = 500 hl
Enthalpy of vapourisation of water at 100 deg C and atmospheric pressure = 2257 kj kg-1
Density of water at 100 deg C = 958 kg m-3
Q = U A dT
I need help solving this please. Its a past exam paper.
does this mean starting vol is 500hl and after one hour vol should be 475hl
Wort volume = 500 hl = 50,000 L / hr
1 L = 10^-3 m^3
50,000 L = 50 m^3 /hr
= 0.833 m^3 / min
= 0.01388 m^3 / sec
Final Enthalpy
= (0.01388)(2739)
= 38.0173 kJ
Initial Enthalpy
= (0.01388)(605)
= 8.3974 kJ
Final - Initial = 29.6199 kJ
Am i on the right track here?
What are the thermodynamic states of the wort and steam entering the device?
What are the thermodynamic states of the wort and steam exiting the device?
Likes sci0x
If it says 5% by mass, doesn't that mean 5% by mass and not by volume ?
And that you evaporate 5%, so not 100 % ?Try to get your units straightened out. 50,000 L = 50 m^3 /hr hurts my eyes !
E.g: m3/h * kJ/kg is not kJ
Advice: take a break, get some rest :wink: .
Okay wort and steam enter the boiler and wort -5% mass and water leave
We have steam enthalpy but not mass = (2739)(x)
We have water enthalpy and density = (605kJ kg-1)(958 kg m-3) = 6227 kJ m-3
Can I say (2739 kJ kg-1)(x) = 6227 kJ m-3
X = 2.27 kg m-3 = steam density
Right direction?
Examiners notes say answer is 0.704 kg/s
Can you show me how to get to this Chester
Right direction?
You still haven't answered my questions.
Wort entering the boiler: Cool
Steam entering boiler: Superheated
Wort leaving boiler: heated to 100 deg C with evaporation
Steam leaving boiler: heat energy supplied to wort, condense to water
Thanks for your help
What is the temperature and pressure of the steam leaving? What makes you think that the entering steam is superheated?
What is the temperature and pressure of the steam entering?
What is the temperature and pressure of the wort leaving?
What is the temperature and pressure of the wort entering?
Temp ? // Pressure: 3 bar g (1 bar = 100,000 Pa) so 300,000 Pa
Temp: 100 deg C // Pressure: 3 bar g = 300,000 Pa
Temp: 100 deg C // Pressure: Atm pressure - 10^5 Pa
Temp: ? // Pressure: Atm pressure
I guess the steam is flowing through tubes in the boiler. This was not clear to me before.
The change in enthalpy of the steam passing through the tubes per kg of this steam is??
You have 50 m^3 / hr of wort entering the boiler and 5% of this evaporates. So the amount that evaporates is 2.5 m^3/hr. What is the mass flow rate in kg/hr of the wort water that evaporates? The rest of the wort does not change at all between inlet and outlet. What is the change in enthalpy per unit kg of the wort that evaporates? What heat transfer rate does this represent (in kJ/hr)?
Hi Chester,
Volume that evaporates is 2.5 m^3 / hr
Can I use density water here to calc mass..
Density = mass/vol
958 kg m-3 = mass / 2.5 m3
2395 kg / hr = mass
= 0.66 kg / sec
2339.04 kj = (enthalpy of vapourisation)(x)
2339.04 kj = x(2257 kj kg-1)
1.036 kg = x
1.036 kg per sec
Can you show me how to finish this off please?
sci0x said:
Hi Chester,
Density = mass/vol
2395 kg / hr = mass
Correct
= 0.66 kg / sec
I asked for the mass flow rate in kg/hr, not kg/sec. Why are you not using an hourly basis, and insisting on using a seconds basis?
This is incorrect. The correct answer to this is given in the problem statement as 2257 kJ/kg
No.
1.036 kg = x
1.036 kg per sec
No. This is all wrong. I didn't ask you anything about the heating steam yet.
From the open system (control volume) version of the first law of thermodynamics, $$0=\dot{Q}-\dot{m}\Delta h$$
or $$0=\dot{Q}-(2395)(2257)$$or$$\dot{Q}=5.406\times\ 10^6\ kJ/hr$$
This is the heat transfer rate from the steam to the wort.
OK so far?
Likes Lnewqban
Okay good with this Chester
OK. For the steam flowing through the heat exchanger tubes immersed in the wort, we are going to do exactly the same thing.
What is the change in enthalpy (in kJ/kg) for the steam between the entrance and exit of the heat exchanger tubers?
In terms of this enthalpy change, the mass flow rate x of the steam in kg/hr, and the rate of heat transfer ##\dot{Q}## from the steam to the wort, what is the open system (control volume) version of the 1st law of thermodynamics applied to the steam passing through the heat exchanger tubes?
Change in enthalpy of steam = 2739 - 605 = 2134 kj kg-1
5.406 x 10^6 kJ hr-1 = (2134 kJ kg-1)x
2533 kg hr-1 = x = flow of steam required ?
Likes Chestermiller
Related to Calculate the flow of steam to heat wort (in the brewing process)
1. How do you calculate the flow of steam needed to heat wort?
The flow of steam needed to heat wort can be calculated using the formula Q = m x Cp x ΔT, where Q is the heat energy required, m is the mass flow rate of steam, Cp is the specific heat capacity of steam, and ΔT is the temperature difference between the steam and the wort.
2. What is the specific heat capacity of steam?
The specific heat capacity of steam is 2.08 kJ/kgK at atmospheric pressure and 100 degrees Celsius. This value may vary slightly depending on the pressure and temperature of the steam.
3. How do you determine the temperature difference between the steam and the wort?
The temperature difference between the steam and the wort can be determined by subtracting the initial temperature of the wort from the desired final temperature. This will give you the ΔT value needed in the calculation for the flow of steam.
4. What is the mass flow rate of steam?
The mass flow rate of steam is the amount of steam that is flowing per unit of time. It is typically measured in kilograms per second (kg/s). This value can be calculated by dividing the heat energy required (Q) by the specific heat capacity of steam (Cp) and the temperature difference (ΔT).
5. How does the flow of steam affect the heating process of wort?
The flow of steam directly affects the heating process of wort as it determines the rate at which heat energy is transferred to the wort. A higher flow rate of steam will result in faster heating of the wort, while a lower flow rate will result in a slower heating process. It is important to calculate the flow of steam accurately to ensure that the wort is heated to the desired temperature in a timely manner.
