Calculate the following commutator [[AB,iℏ], A]
To calculate the commutator [[AB, iℏ], A], start by defining C as [AB, iℏ]. The first step involves finding the inner commutator [AB, iℏ], which simplifies the process. After determining C, substitute it back into the expression to find [C, A]. This method clarifies the calculation and leads to the desired result efficiently. Understanding these steps is crucial for solving similar commutator problems in quantum mechanics.
chris1223123
I've seen this question in a textbook
I'm not to sure how you go about it i know [A,B] = AB-BA
Let ##C=[AB,i\hbar]##.
Find ##[C,A]##
Substitute the definition for ##C## in the result you got.
Likes chris1223123
Find ##[C,A]##
Thank you! that makes sense
You can also start by calculating the inner commutator ##[AB,i \hbar]##.
Likes chris1223123
