Calculate the heat needed to change 2kg of ice to steam
In summary, to change 2kg of ice at 0 degrees C to steam at 100 degrees C, you would need to use 6000J of heat.
honkydora5
1)Calculate the heat needed to change 2kg of ice at 0 degrees C to steam at 100 degrees C.
The attempt at a solution
2x334000=66800J
2x4200x100=840000J
2x2260000=4520000J
total=5426800J should be 6120000J somehow
2)An electric kettle produces 3000J of heat every second.It is filled with water ,weighed and switched on. After coming to the boil,it is left on for a further 80 second and then switched off.It is found to be 100g lighter.Calculate the specific latent heat of steam.
Thank for help!
Latent heat of melting is 333J per gram
Heat capacity of water is 4.18J per gram and Kelvin
Latent heat of vapourization is 2260 per gram
So in total I get: 6146000 which is much closer to the correct answer 6120000J
It just depends what table you are using.
For your second question, you need to show some work. Hint: What is the definition of Latent Heat.
Also, what has this to do with Advanced physics? Sounds like introductory thermodynamics according to me.
That sounds good to me ,but can you show some calculations?How did you get 6146000
P.S I know that it is basic physics but I am stuck.
Thanks for help anyway.
by using the figures I just posted? what else?
Who are YOU to ask ME for calculations? This is charity..
By using those calculations i get 5426800.so its not much help is it?
Then maybe you need to practive using the calculator properly.
I got 6022000 now LOL
Can you SHOW you calculations perhaps?
As I said, it is just a matter of having the same table as the person who constructed the answer. Dont bother so much about numbers. The important thing to know is to use the latent heat and specific heat.
By the way, I got 6028000 using the figures you had in your first post.
thanks for spoting mistake! i missed one zero . uuuufffff.so I am not that bad??
Any chance for help with second one?
The specific latent heat of vaporisation of substence is the amount of energy needed to boil the liquid to gas without changing the temperature.
And again I got 240J/kg should be 2400000
Now careful, you said that answer is 2400000, same units as you?? Sometimes one forget to compare units..
The amount of energy is 3000*80J
The mass is 100g, which is 2400J/g = 2400 000J/kg !
was it that simple? I think I will waste half of my life making mistakes! ;-(((
Thanks for your time and help!
Sometimes it is really simple :)
FAQ: Calculate the heat needed to change 2kg of ice to steam
How do you calculate the heat needed to change 2kg of ice to steam?
The heat needed to change 2kg of ice to steam can be calculated using the formula Q = m * L, where Q is the heat energy needed, m is the mass of the substance, and L is the specific latent heat of fusion or vaporization.
What is the specific latent heat of fusion and vaporization?
The specific latent heat of fusion is the amount of heat energy needed to change a substance from solid to liquid at its melting point. The specific latent heat of vaporization is the amount of heat energy needed to change a substance from liquid to gas at its boiling point.
What is the mass of the substance in the calculation?
The mass of the substance in the calculation is 2kg, as stated in the question.
How do you determine the specific latent heat values for ice and steam?
The specific latent heat values for ice and steam can be found in reference tables or online sources. The specific latent heat of fusion for ice is 334 kJ/kg and the specific latent heat of vaporization for steam is 2260 kJ/kg.
Can the specific latent heat values vary for different substances?
Yes, the specific latent heat values can vary for different substances. This is because each substance has a different molecular structure and therefore requires different amounts of energy to change states. The specific latent heat values can also vary for the same substance at different temperatures and pressures.
