Calculate the individual voltage, current and power in series and para
To calculate the voltage per globe in a circuit with 16 globes, dividing the total voltage of 24V by the number of globes yields 1.5V per globe, though the accuracy is questioned. The total resistance for 8 globes is calculated as 15 ohms, leading to an individual globe resistance of 1.875 ohms, resulting in a current of 0.8A per globe using Ohm's Law. Power is calculated using P = IV, giving 1.2W per globe, but the correctness of these calculations is uncertain. The discussion raises questions about the impact of series versus parallel configurations on voltage distribution. A diagram is suggested to clarify voltage drops across the bulbs and overall circuit behavior.
nickbb12
A set of 16 party lights were purchased for the patio, 2x of 8 sets of bulbs are in parallel with each other, so if i disconnect one bulb, only half of the lights will go out. When all bulbs are functional they draw 3.2Amps from the 24.0V transformer. I need to determine the voltage across each globe, the current through each globe, the power consumed by each globe and finally, if we had a power board with a circuit breaker rated to flip at 10A, how many sets of lights could I operate before flipping the circuit breaker? Thanks :)
V = IR
P = IV
V = 24V
I = 3.2A
16 globes (2x 8 in parallel) (8 globes in series)
To determine the voltage I did voltage/number of globes:
24/16 = 1.5V per globe
- Not sure if this is correct or not
To determine current, I figured out using resistance formulas that the resistance for each set of 8 globes is 15 ohms
R = V/I
24/3.2 = 7.5 ohms total resistance
7.5-1 = 2 * 15-1
Each set of 8 has resistance of 15 ohms.
therefore each globe has an individual resistance of 1.875 ohms, I then used I = V/R to get 0.8A per globe.
To solve power I simply did P = IV,
1.5 x 0.8 = 1.2W
- Again, not sure if this is correct
The last one I'm stumped, no idea how I could figure it out.
Thanks in advance for people who reply :)
What answer would you have given if all 16 had been in series?
Should it make a difference that it consists of two parallel strings of 8 instead?
Draw a diagram of the circuit, marking the ends with voltages (0 at one end, 24 at the other, say).
If the voltage drop across each bulb is v, what should the difference at the ends be?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
