MHB Calculate the length of the fourth side edge.
  • Thread starter Thread starter ghostfirefox
    Edge Length
To calculate the length of the fourth lateral edge of a pyramid with three known edges measuring 6016, 2370, and 4350, a system of equations based on the distance formula is established. The apex of the pyramid is represented by coordinates (a, b, c), while the base corners are defined in the xy-plane. By manipulating the equations derived from the distances, a unique integral value for the fourth edge, denoted as d, is determined to lie between 4350 and 6016. The discussion emphasizes solving the equations by subtracting pairs to simplify the calculations. Ultimately, the method aims to isolate d for a precise solution.
ghostfirefox
The three lateral edges of a pyramid based on a square are 6016, 2370 and 4350 long. Calculate the length of the fourth lateral edge. We assume that edges 6016 and 2370 extend from the opposite tops of the base.
Mathematics news on Phys.org
let the four corners of the square base with side length $s$ lie in the x y plane with positions
$(0,0,0)$, $(s,0,0)$, $(s,s,0)$, and $(0,s,0)$
let the apex of the pyramid be at position $(a,b,c)$
... assume that edges 6016 and 2370 extend from the opposite tops of the base
using the distance formula between two points in space yields the following equations
$a^2+b^2+c^2 = 6016^2$
$(a-s)^2+(b-s)^2+c^2 = 2370^2$
$(a-s)^2+b^2+c^2=4350^2$
$a^2+(b-s)^2+c^2 = d^2$, where $d$ is the length of the fourth edge
use the system of equations to solve for $d$ ... I get a unique integral value for $d$ such that $4350 < d < 6016$
I tried to calculate this, but there are too many variables in this system of equations.
Subtract the 3rd equation from the 1st.
Subtract the 2nd equation from the 4th.
Work the solution for $d$ from the resulting two equations.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
