MHB Calculate the Length & Potential Energy of a Sliding Box on a Ramp
The discussion focuses on calculating the length of a ramp and the potential energy loss of a box sliding down it. The ramp has a rise of 10 cm for every 80 cm along its surface, and a box with a mass of 50 kg slides down, experiencing a coefficient of friction of 0.03. The key equation derived from energy conservation is Δx = v_f² / (2g( sin(θ) - μ cos(θ))), which leads to a calculated ramp length of approximately 2.1 m. Participants emphasize using energy equations rather than Newton's second law for this problem. The final calculations confirm the textbook answer, clarifying the method for determining the ramp's length and energy loss.
Shah 72
MHB
A ramp rises 10cm for every 80cm along the sloping surface. A box of mass 50 kg slides down the ramp starting from rest at the top of the ramp. The coefficient of friction between the ramp and the box is 0.03 and no other resistance acts.
The box is traveling at 2 m/s when it reaches the bottom of the ramp.
Find the length of the ramp
Find the loss in the potential energy of the box.
I don't understand how to calculate. Pls help.
Mathematics news on Phys.org
$\theta$ = ramp angle
$\Delta x$ = length of the ramp
you are given info that can be used to determine $\sin{\theta}$
$mg \cdot \Delta x \sin{\theta} - \mu mg\cos{\theta} \cdot \Delta x = \dfrac{1}{2}m v_f^2$
Thank you!
I tried doing but not getting the ans.
m = 50 kg, coefficient of friction is 0.03
F= m×a 500sin theta- 0.03 × 500 cos theta= 50a
I don't know how to calculate the length of the ramp.
Pls can you help.
Why are you messing around with Newton’s 2nd law? … solve the energy equation I posted for $\Delta x$, then substitute in your given values.
I haven't yet learned this method.
So I get distance = 100m
But the textbook ans says 2.10m
This is just derived from F= ma only
$F= m v \frac{dv}{ds}$
$ F ds = m v dv $
integrate this you will get the result also known as Work energy theorem.
well, it's about time you learned ...
let the bottom of the ramp be the zero for gravitational potential energy
(initial quantity of mechanical energy) - (work done by friction) = (final quantity of mechanical energy)
the block starts at rest, so the initial quantity of mechanical energy is gravitational potential energy, $mgh_0$ where $h_0 = \Delta x \sin{\theta}$
work done by kinetic energy is $f \cdot \Delta x = \mu mg\cos{\theta} \Delta x$
final quantity of mechanical energy is strictly kinetic, $K = \dfrac{1}{2}mv_f^2$$mg \Delta x \sin{\theta} - \mu mg \cos{\theta} \Delta x = \dfrac{1}{2}mv_f^2$
$\Delta x(g \sin{\theta} - \mu g \cos{\theta}) = \dfrac{1}{2}v_f^2$
$\color{red} \Delta x = \dfrac{v_f^2}{2g(\sin{\theta} - \mu\cos{\theta})}$
I get $\Delta x = 2.1 \, m$Let's check by messing with Newton's 2nd ...
$a = \dfrac{F_{net}}{m} = \dfrac{mg \sin{\theta} - \mu mg \cos{\theta}}{m}$
$a = g(\sin{\theta} - \mu \cos{\theta})$
$v_f^2 = v_0^2 + 2a \Delta x \implies \Delta x = \dfrac{v_f^2 - v_0^2}{2a} $
$\color{red} \Delta x = \dfrac{v_f^2}{2g(\sin{\theta} - \mu \cos{\theta})}$
Well ... I'll be dipped in dog :poop:
Thanks a lotttt!
$ F ds = m v dv $
Thanks!
